Online Now [432]:
Visitors: 432
Today: 56821
Total: 142567262
Forums › The Car › 206 Problems › Car cutting out
Car cutting out
jonnym92
PostPosted: Tue Jun 07, 2011 9:45 am Up
This morining i started the car and in neutral the revs dropped instantly to 0 and it cut out. i then kept the accelerator down and got it off the drive and as i braked and put the clutch in to get it into first the revs dropped to 0 again cutting it out. this happens at every junction or everytie you stopp basically. ive never known this to happen before and it was fine last night as i was in it for about 100 miles. there's plenty of petrol in it but the car wont start at all now.
Any help appreciated as i need it for work
Its a 2001 1.4 quicksilver also
Jonny
louise599
PostPosted: Tue Jun 07, 2011 9:58 am Up
Hi there,
Please post this on my forum (peugeout 206 engine cut out) im trying to get 100 people with this same problem on my forum to get it to watchdog!!! hopefully they will sort this problem out free of charge as there are so many of us with this problem!!!!
Please read my forum, i have exactly the same problem!!!!
Louise599 Smile
Please help get 100 posts on errors with engine cut outs peugeot 206!! we will beat peugeot with this problem Smile
MrrNoName
PostPosted: Tue Jun 07, 2011 10:03 am Up
idle control valve, takes less then 5 mins to change on a 1.4 engine
can pick a non-pug one up on ebay for less then £20 and they work fine.
Ash
PostPosted: Tue Jun 07, 2011 10:10 am Up
Or just clean it.
hwakeford
PostPosted: Thu Jun 09, 2011 2:43 am Up
I'm having the same problem with mine at the mo (2.0 gti 2001). At standstill revs are jumping between 400-800 and it sounds like its chugging. Drives fine, until you slow down to stop, drop the clutch and all the revs drop and cuts out again. I'm puttin this down to being the ICV. Is it simple to get to and replace?
PostPosted: Thu Jun 09, 2011 2:47 am Up
206info.co.uk/Forums/v...ntrol.html
PostPosted: Thu Jun 09, 2011 3:04 am Up
louise599 wrote:
Hi there,
Louise599 Smile
BLAH BLAH BLAH the same old b******s being repeated again & again Rolling Eyes
Change the record, Peugeot fixed the cut out problem YEARS ago
Its not Peugeot's fault your dealer is incompetent
hwakeford
PostPosted: Thu Jun 09, 2011 3:08 am Up
If it needs replacing is there a specific one you need to get?!
PostPosted: Thu Jun 09, 2011 3:14 am Up
Yes, one for the GTi.
cgi.ebay.co.uk/PEUGEOT...41522a5051
www.eurocarparts.com/e...02f4e&IDLC
I'm unsure of the Peugeot part cost. Worth calling them.
hwakeford
PostPosted: Thu Jun 30, 2011 1:36 pm Up
Followed your advice and cleaned the ICV twice.. Still continues to bounce the revs, and cutting out when idle. I ordered the new part from Peugeot and replaced this today. When we turn the car on, revs are shooting up to 3500-4000 and not settling down. Why would this be? Is there anything else that could be causing the revs to drop??
matt001
PostPosted: Thu Jun 30, 2011 5:55 pm Up
I think turning ignition 2 clicks (ie not starting engine) for 10 seconds then off again (5 times) should get it back to idle when you next start engine. Im just passing on what i read somewhere, not tried it myself.
206 XSi (\'51)
southwestchap
PostPosted: Fri Jul 01, 2011 8:01 am Up
I had a 1.4 cutting out when dipping the clutch approaching a junction. Turned out to be the ECU coolent sensor....
There's two on the block, green and blue plugs, its one of them... (one is the temp gauge and the other is ECU temp)
