Latest: tebas93089
Overall: 17179
Online Now [156]:
Visitors: 155
Today: 21029
Total: 138540697
Forums › The Car › 206 Problems › brake pedal
brake pedal
dumdum0910
PostPosted: Wed Jul 06, 2011 6:24 am Up
some times when im driving my brake pedal goes solid as if something is behind it stopping it and when i realese and push on it again it goes back to normal. what could the problem be as it starting to get scary slowing from 70 :O. its got new pads on the front aswell
MrrNoName
PostPosted: Wed Jul 06, 2011 6:28 am Up
does it feel like when the engines off and you press the brake (i.e no engine assistance?) or does it feel like somethings jamming / getting in the way of the pedal or rod?
sounds really dangerous, you want to get it sorted before you continue driving tbh
dumdum0910
PostPosted: Wed Jul 06, 2011 6:56 am Up
feels like something jamming it
DREWDEN
PostPosted: Wed Jul 06, 2011 8:25 am Up
there's a test you can do, to rule out the servos not faulty, with the car parked up and the engine running, pump the foot pedal a few times
until it goes solid. then switch the engine off.
Then lightly touch the break pedal downwords, they shouldn't be any resistance at all.
This test can rule out your servo.
206 2ltr Hdi glx 53 plate
PostPosted: Wed Jul 06, 2011 8:58 am Up
looks like servo problem to me.
dumdum0910
PostPosted: Wed Jul 06, 2011 12:31 pm Up
ill try that test later
dumdum0910
PostPosted: Wed Jul 06, 2011 12:32 pm Up
could it have something to do with the abs?
dumdum0910
PostPosted: Wed Jul 06, 2011 2:42 pm Up
just done the test the pedal didnt go solid after a few pumps . i could hear a sucking noise when i push the pedal then i turned the engine off and the pedal went solid? is there a service kit you can buy to service the servo? or is a easier and cheaper to replace the servo
DREWDEN
PostPosted: Wed Jul 06, 2011 3:17 pm Up
Im the dumdum sorry to give wrong fnfo, just tried on my car,
with engine switched off pump the pedal till it becomes hard.
then start up, the pedal then should go to the floor without much force.(thats the servo working)
sorry.
dumdum0910
PostPosted: Wed Jul 06, 2011 3:19 pm Up
so my servo is ok ? what else could it be? i will try bleeding the brakes when my old man is back from is holiday . also could it be the abs pump kicking in for no reason?
dumdum0910
PostPosted: Wed Jul 20, 2011 9:59 am Up
i no this old but i finally got round to popping in to my old college and asked my old tutor what he thinks could be the problem and he mentioned that the flexi pipes could be flexing so much its stopping the brake fluid from moving . could this be possible ?
