Latest: morgan20
Overall: 17135
Online Now [248]:
Visitors: 247
Today: 1694
Total: 110713312
Forums › The Car › 206 Talk › Well, That wasted my entire day :p
MrrNoName
PostPosted: Wed Jul 06, 2011 10:23 am Up
Ok so, the day started with me taking a trip to pug to pick up a glovebox light and switch as my car already has the wireing behind the glovebox ready to install. The 1hr 30 min round trip went great, I sucessfully aquired both parts Smile
got home, removed the standard bulb and fitted an LED one, disconnected the battery and fitted both parts, reconnected the battery and nothing Sad . Ok i thought, must be the LED in the wrong way around. Disconnected the battery again and swapped the LED round. Reconnected and nothing Sad messed around with the switch and the light fixture for a couple of hours, tested the switch, works fine, tested the light, works fine.
Finally came to the conclusion that maybe it wasnt wired up at the other end?
put the key in the ignition to do my window up because its just started raining and WOOAH it lit up Very Happy
Why didnt I think of that about 3 hours ago lol, of course it wont work without the key in, or a open glovebox could flatten the battery!
Still bloody annoying that I didnt think about that hours ago though Wink
PostPosted: Wed Jul 06, 2011 10:27 am Up
Lack of common sense...oh dear Laughing
Abzynthe
PostPosted: Wed Jul 06, 2011 10:36 am Up
East Area Rep - Abzynthe
Laughing
At least it works Wink
smiddies
PostPosted: Wed Jul 06, 2011 10:37 am Up
It seems more productive then my day tbh!!
PostPosted: Wed Jul 06, 2011 10:47 am Up
DOH!!!
Teebag
PostPosted: Wed Jul 06, 2011 11:21 am Up
Razpulsedj wrote:
:doh:
What He Said
my garage inc mod list:
- Antix
JE_180
PostPosted: Wed Jul 06, 2011 11:31 am Up
Isn't it satisfying when you fault find though Smile
PostPosted: Wed Jul 06, 2011 11:54 am Up
You're not the first to think the light wasn't working and then found out it only works with the ignition on. A quick search would throw up this, and the problem would have been sorted in 5 minutes.
PostPosted: Wed Jul 06, 2011 12:35 pm Up
Don't worry I do stupid things like this that waste my time unnecessarily on a daily basis! lol
SmithyXSI
PostPosted: Thu Jul 07, 2011 12:31 pm Up
Haha I've done loads like this before!
I had to go and help a mate yesterday because he'd jacked the car up without loosening the wheel bolts first and couldnt work out how to press the brakes and undo the wheel nut at the same time...
2003 206 2.0HDi. I miss my 106 GTi.
Ali_H
PostPosted: Thu Jul 07, 2011 12:35 pm Up
LOLLAGE
kurtis wrote:
kingdom200
PostPosted: Thu Jul 07, 2011 12:45 pm Up
i did this with my HID's it wasn't until about attempt 5 of removing them i turned the engine on lol
PUG1OFF Cat Cams/ ECU project
Rob2859
PostPosted: Thu Jul 07, 2011 5:52 pm Up
At least you didn't pull your drive shaft out while changing the wishbone Very Happy I think the circlip has fallen inside the diff.
I got a glove box light and switch from a scrap yard and found I didn't have the wires so I never bothered putting it in.
iainlovatt
PostPosted: Thu Jul 07, 2011 5:57 pm Up
The funny thing is i made the same mistake only 2 weeks ago! i put my problem in the problem section and someone explained to me (put the keys in ignition and see what happens) lol! funny issues!
(My Garage)
