Latest: lio94
Overall: 17181
Online Now [145]:
Visitors: 144
Today: 27580
Total: 141466608
Forums › The Car › 206 Problems › low power won`t rev past 3,000rpm
gc3746
PostPosted: Thu Jul 07, 2011 1:41 pm Up
Took his 206 to the local garage and they did a diagnostic check on it, the ECU was showing several fault codes. The ecu was removed and sent to a speacialist to be repaired, upon refitting still showing fault codes, by chance on of thier technicians was passing so tested it in situ, diagnosis was that the ecu needed replacing, I bought one which was tested on a car before being recoded to his so we would not have to change the locks etc. No difference to the car, took the car back to the same garage today they ran the diagnostics again, no fault codes found. So we have nothing to go on other than the potentially expensive route of trial & error.
The car is slow to rev, power picks up around 2,200rpm as the turbo spools up, then flatlines a 3,000rpm, can get the car up to 70mph by short shifting and riding the 700rpm "power band", but any incline brings it down to 50mph. fuel consumpion is noticably worse also.
I`ve got a list of things it could be, but it would greatly help if someone had personal experience of this problem themselves.
gazzer
2Oh!6
PostPosted: Thu Jul 07, 2011 1:48 pm Up
Limp mode?
VTEC goes BWAAAAAAH! Wink
PostPosted: Thu Jul 07, 2011 1:51 pm Up
Limp mode, needs a diagnostic test.
Andy180+
PostPosted: Thu Jul 07, 2011 1:57 pm Up
sometimes it better to just go with the people that know best !!!
PostPosted: Thu Jul 07, 2011 2:01 pm Up
What was the initial problem?
If you replaced the ECU did you replace the BSI or get it unlocked?
Is it a back street garage?
What they using to code read it with?
mjsroofing
PostPosted: Fri Jul 08, 2011 12:58 pm Up
limp mode, just had this with a fiesta and that come up as eac fail which is elecrical accelerator control fail, turned out to be the plug going into the fuel rail for the fly by wire under the fuel filter, this was the 1.4 hdi , what engine you got???
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
