Online Now [591]:
Visitors: 590
Today: 120853
Total: 145083278
Forums › The Car › 206 Talk › removing bonnet vents
Forum Index › 206 Talk
bisphenol-a
PostPosted: Fri Jul 08, 2011 4:04 am Up
i thought those clips were those simple mushroom clips i get from the boot lining. but damn it's difficult to remove and i dont wanna try too hard before i break/snap/destroy anything.
i just want to remove it to give it a coat of paint and snap back on.
possible?
eddicus
PostPosted: Fri Jul 08, 2011 4:45 am Up
Use a flat head screw driver to prize the middle out, then the clip comes straight out. Pretty easy just don't be too heavy handed.
206 1.4 lx loads of mods coming!!
PostPosted: Fri Jul 08, 2011 5:02 am Up
Use a fork Wink
j4m1e
PostPosted: Fri Jul 08, 2011 5:18 am Up
yeah i ended up snipping mine as they wouldnt budge obvs then had to buy some new ones :/ lol but as i found out after taking time slow prize them out/off and they will come Wink
Jamie VW Polo
eddicus
PostPosted: Fri Jul 08, 2011 5:34 am Up
Jordan_xsi wrote:
Use a fork Wink
This works also ;)........
bisphenol-a
PostPosted: Fri Jul 08, 2011 9:36 am Up
you mean break the honey comb grill out?
Abzynthe
PostPosted: Fri Jul 08, 2011 9:46 am Up
East Area Rep - Abzynthe
no, jam a fork or screwdriver into the clip to pull the middle of the clip out.
bisphenol-a
PostPosted: Fri Jul 08, 2011 10:56 am Up
i broke one clip earlier in the day.
top left corner clip was busted
so i gotta try and remove the clips (4) at the corners with considerable force and a fork might make the job easier? looks like i gotta head down to the dealers for new clips. how do you remove the clips that are already busted? cut and clip your way through the bits and pieces?
anyone got a part number on these? or are these the same as those clips that holds the boot lining in place?
thank you
