Latest: tebas93089
Overall: 17179
Online Now [74]:
Visitors: 74
Today: 17947
Total: 138119897
Forums › The Car › 206 Problems › Two problems!!!
Two problems!!!
Go to page Previous  1, 2
pug206lx
PostPosted: Fri Jul 08, 2011 3:41 pm Up
the very top layer of rubber? thats common and wont be linked to your problem
PostPosted: Sat Jul 09, 2011 1:49 am Up
DREWDEN wrote:
there's products out there that you can buy, that cieculates the system and seals minor leaks.
never had to use them myself.
radseal one i know of. then see how that goes.
An egg does the same thing. You could use radweld, but I don't rate it.
If the rad is leaking, then you would be better off getting it repaired or exchanged.
celts1888
PostPosted: Sat Jul 09, 2011 3:19 am Up
Yes the very top rubber that runs around the outside of the cylinder head.
PostPosted: Sat Jul 09, 2011 3:33 am Up
To be on the safe side, I'd start off by replacing the hose & clip.
celts1888
PostPosted: Mon Jul 18, 2011 2:45 pm Up
Topic updated any info on the gear lever mount issue?
Page 2 of 2
