Posted: Mon Jul 11, 2011 9:39 am |
right, i have a horrible persistant rattle/squeek that sounds like its coming from the glovebox/passenger dash/passenger mirror area.... i've searched and fiddled around and cant feel anything loose!
its a constant squeek over any tiny bump and its doing my head in, a joke had developed that there's a mouse in my glovebox
anyone had this before and solved it or are there any common rattle causes i should know about? or anyone even have any ideas?
Posted: Mon Jul 11, 2011 9:41 am |
I had a squeek/rattle on the 180 over towards the passenger side, I adjusted the door lock and this solved it...may be worth a try.
Posted: Mon Jul 11, 2011 9:42 am |
ive got one but its coming from my coilover being set too high, waiting on spacers so i can get it lower to stop the noise
Big_Rich180 wrote: |
I had a squeek/rattle on the 180 over towards the passenger side, I adjusted the door lock and this solved it...may be worth a try. |
i'll have a look, im just gonna search until i find it i hate it that much ... i know its french and you will get the odd rattle but this one is constant!
Posted: Mon Jul 11, 2011 9:43 am |
Kersh wrote: |
ive got one but its coming from my coilover being set too high, waiting on spacers so i can get it lower to stop the noise  |
coilovers being set too high is not likely to be my problem
Posted: Mon Jul 11, 2011 9:44 am |
JordGJ wrote: |
Kersh wrote: |
coilovers being set too high is not likely to be my problem  |
haha fair point, top mount bearing??
Posted: Mon Jul 11, 2011 10:12 am |
i remember reading something similar sometime ago. Someone had a rattle/squeeking from the same area. If im right, it was recommended putting a squirt of wd40 down the handbrake button. I know it sounds weird but it definately had the same noise etc and was cured with the above. Try it and post back!
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Mon Jul 11, 2011 10:56 am |
probably rubbish peugeot trim checked all the screws on everything are tight they do tend to rattle loose sometimes especially the seat handles
