Latest: tbafonso
Overall: 17130
Online Now [139]:
Visitors: 138
Today: 41060
Total: 103776833
Forums › The Car › 206 Problems › misfiring (Only when hot)
gmcminn
PostPosted: Fri Jul 15, 2011 2:30 pm Up
hi folks really need help. Have a 2003 pug 206 1.4 petrol. It starts & runs perfect but temperature goes up to bout 95degrees. Also when idling hot the engine managment light flashes & bleeps and misfires badly.
If i turn car off & let cool down it resets itself & runs perfectly until hot again.
I have changed the 4x spark plugs, both temperature sensors (Blue & green plugs), also got 2nd hand coil pack off friend (which was working ok).
Have had it on the diagnostics & it just says misfiring.
Please help as i hate paying over the odds at garages.lol
PostPosted: Fri Jul 15, 2011 2:35 pm Up
is the low speed fan working? should cut in about 93ish
misfiring, what about injectors?
gmcminn
PostPosted: Fri Jul 15, 2011 2:43 pm Up
Not sure about the low speed. How can i test it???
Thought id try the simple stuff before trying injectors etc. But car running great until i idle at high temperature. U think idling control valve would cause it???
