Latest: Kifi69
Overall: 17183
Online Now [431]:
Visitors: 430
Today: 75537
Total: 144703555
Forums › The Car › 206 Problems › noisey tappets?
noisey tappets?
dumdum0910
PostPosted: Fri Jul 15, 2011 12:54 pm Up
since ive replaced the headgasket on my 206 i keep getting a loud ticking once the engine has warmed up. i have checked the gaps on all the tappets about 3 times in the last 2 weeks but there still noisey. what else could the problem be as its getting rather annoying ?
its still running fine and no problems
its the 1.1 tu1pj engine with 60k on the clock its also had a recent service
PostPosted: Fri Jul 15, 2011 12:55 pm Up
if changing the oil don't help then that means you will need new lifters
macj
PostPosted: Fri Jul 15, 2011 12:59 pm Up
give it a Forte engine flush.... you have some hydraulic lifter issues
imjeeves
PostPosted: Fri Jul 15, 2011 1:09 pm Up
I had this and it was the cambelt crankshaft bolt was loose. Make sure its 100% tight
Daza
PostPosted: Fri Jul 15, 2011 1:14 pm Up
I get this too however mine is noisey when the engine first starts then when it warms up the noise gets quiter! also had full service about 1 month ago
PostPosted: Fri Jul 15, 2011 4:23 pm Up
Mine seems to start ticking when its stood idling for more than 10 seconds e.g when sat at trafic lights when its warm. Not too sure what it is.
xXx_LIL_P_xXx
PostPosted: Fri Jul 15, 2011 5:00 pm Up
i have the same problem bfs dad has just changed the head and done a service and since then its very tappy and exhaust sounds very raspy! x
Black 206 1.1 V reg (00), 15" Sirocco Alloy Wheels, Colour Coded Sports Bumpers with Fog Lights, Standard Spoiler, Bosch Aerotwins, Phase 2 Rear Lights, Crystal Head Lights, SP Wheel Arches, GTi Fuel Cap, GTi Half Leather Interior, Official 206 GTi Kickplates, GTi Vent Sliders, Phase 2 Boot Handle (with key hole)
dumdum0910
PostPosted: Sat Jul 16, 2011 2:55 am Up
also i had a look on the internet and found the guide on adjusting them is cylinder 1 gearbox side or pulley side ?
PostPosted: Sat Jul 16, 2011 3:02 am Up
don't think you can adjust the lifters are they are self adjusted
dumdum0910
PostPosted: Sat Jul 16, 2011 3:21 am Up
nope there not self adjusting .
PostPosted: Sat Jul 16, 2011 3:37 am Up
gearbox end
dumdum0910
PostPosted: Sat Jul 16, 2011 3:39 am Up
ok i also done the tappets on my mates saxo 1.1 and it came out worse with the info i had
valve clearances are- 0.20mm for all the inlet valves and 0.40mm for the exhaust valves
No.1 exaust valve fully open - adjust No.3 inlet and No.4 exhaust.
No.3 exhaust vale fully open - adjust No4 inlet and No2 exhaust.
No4 exhaust open- adjust No2 inlet and No1 exhaust.
No2 exhaust open - adjust No1 inlet and No3 exhaust.
dumdum0910
PostPosted: Sat Jul 16, 2011 3:40 am Up
some people are also saying the engine has to be hot? is this right?
GingeWrexham
PostPosted: Tue Jul 19, 2011 6:08 am Up
I had same problem for months, tried engine flush, tappet lifter the lot. and it just ended up bein a loose spark plug ha
2002 206 GTI
