Posted: Sat Jul 16, 2011 4:00 pm |
Is replacing the ABS pump on a 206 a easy job? straight swap?
any bleeding needed, or could be any electronic issues after fitting it?
i have just put up a deposit for a 206 that am picking it up next wednesday.
when i was inspecting it i noticed there was quite empty space next to the air filter box and noticed 2 disconnected plugs, i was curious... and found out the abs pump is missing....
and according to the seller (a dealer) it has a fresh mot.
any ideas? the car is cheap... £925 for a 2002 206 2.0hdi ..... so if its just getting a pump and fitting... and the job is easy im up for it... as the pump in my local scrappy is around 20 quid...
any ideas? thanks in advance
| 2002 Peugeot 206 2.0 Hdi 90
2002 Citroen C5 Hdi 110 Estate with some Poke  | |
Posted: Sat Jul 16, 2011 4:04 pm |
Might not have ABS as standard
Posted: Sat Jul 16, 2011 4:09 pm |
would be a nighmare to retrofit ABS
Posted: Sat Jul 16, 2011 4:12 pm |
i thought they all came with abs.... maybe this one hasn´t
the model is 2002 PEUGEOT 206 2.0 HDi 90 LX SR 3dr....
is there any way to find that its the non abs or it was fiddled about?
thanks
Posted: Sat Jul 16, 2011 4:14 pm |
LX was a poverty spec, doubt it will have come with ABS
If you get the chassis number, I'll look it up for you
Posted: Sat Jul 16, 2011 4:18 pm |
when i was looking at 206 before i got mine i looked at a couple that never had abs
| if it dont scuff the ruff it aint low enuf | |
Posted: Sat Jul 16, 2011 4:20 pm |
mine don't have abs.
2.0HDi d-turbo
Posted: Sat Jul 16, 2011 4:24 pm |
thanks for the reply's i was getting worried about it...
thanks again
Posted: Sun Jul 17, 2011 1:36 am |
It seems strange to me that 206 doesnt have ABS in some configs - I thought it would of been a standard thing!
Posted: Sun Jul 17, 2011 1:39 am |
There would be more than just a couple of plugs disconnected if the ABS unit had been removed. There would be all the plumbing to the brakes that would be sat doing nothing.
Posted: Sun Jul 17, 2011 1:57 am |
Trade Rating: +45
I was guna say surely if the abs pump had just been removed then the brakes wouldnt work
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
