Posted: Fri Jul 08, 2011 3:41 pm |
the very top layer of rubber? thats common and wont be linked to your problem
Posted: Sat Jul 09, 2011 1:49 am |
| DREWDEN wrote: |
there's products out there that you can buy, that cieculates the system and seals minor leaks.
never had to use them myself.
radseal one i know of. then see how that goes. |
An egg does the same thing. You could use radweld, but I don't rate it.
If the rad is leaking, then you would be better off getting it repaired or exchanged.
Posted: Sat Jul 09, 2011 3:19 am |
| pug206lx wrote: |
| the very top layer of rubber? thats common and wont be linked to your problem |
Yes the very top rubber that runs around the outside of the cylinder head.
Posted: Sat Jul 09, 2011 3:33 am |
To be on the safe side, I'd start off by replacing the hose & clip.
Posted: Mon Jul 18, 2011 2:45 pm |
Topic updated any info on the gear lever mount issue?
