Latest: jackrox1992
Overall: 17186
Online Now [998]:
Visitors: 997
Today: 121014
Total: 148649085
Forums › The Car › 206 Problems › ball joint gone - where to buy from?
bigup
PostPosted: Wed Jul 20, 2011 2:59 pm Up
looks like my nearside front ball joint has gone and wheel has some play and makes some noises when turning right
where can i buy one from?
2003 206 1.4 HDi Style 3 Door
PostPosted: Wed Jul 20, 2011 3:00 pm Up
Peugeot is £168, Euro Car Parts was £50, GSF was £38 when Ive just bought some
Euro Car Parts or the dealer. You have to buy the whole wishbone.
Antknee
wheres it gone?
bigup
PostPosted: Wed Jul 20, 2011 3:03 pm Up
thanks, the garage rang his parts guy and he said £60 plus vat and that i had to buy the whole arm with it.
il check GSF out and ECP
PostPosted: Wed Jul 20, 2011 3:06 pm Up
what about egay wishbone? you can't beat them in terms of price Razz
bigup
PostPosted: Wed Jul 20, 2011 3:19 pm Up
is this the part im after?
PostPosted: Wed Jul 20, 2011 3:21 pm Up
yeah
Ste
PostPosted: Wed Jul 20, 2011 3:29 pm Up
Staff - Ste
Shocked you cant beat them for price, but when you have to replace ebay (egay) wishbones every 6 months because there crap quality it works out cheaper to get an OEM one Laughing
The Cars:
bigup
thanks
are wishbones changed in pairs? or will changing one side do?
also is it recommended to change the drop link too when changing wishbone?
imjeeves
PostPosted: Wed Jul 20, 2011 3:37 pm Up
No you could just get one wishbone if you want
The drop link is not connected to the wishbone so changing it would only be worth while if it knackered
bigup
PostPosted: Wed Jul 20, 2011 3:40 pm Up
stunning! thanks Smile
drunknmunky
PostPosted: Wed Jul 20, 2011 3:42 pm Up
total hijack but how easy is it to fit yourself im pretty ok with mechanical stuff usually just aint done one in a good few years or done one on a 206 yet and have to do mine tomorrow and have no option of taking it to the garage Laughing
PostPosted: Wed Jul 20, 2011 3:59 pm Up
Laughing i was just trying to be funny Razz
imjeeves
PostPosted: Wed Jul 20, 2011 4:19 pm Up
Its not too difficult. Can be a bit of a fiddle to get the ball joint back in the hub correctly.
Remove wheel
Remove ball joint to hub bolt.
Getting the wishbone out of the hub is hard work. Keep belting it with a hammer / get a big bar on it to get it out the hub.
Remove two female torque bolts from the subframe and try to push the hub / driveshaft out the way to get the bolts out. In future just put the bolts up the way as its then easy to do next time. If you cant get them out or enough clearance then its a driveshaft out job.
Remove old wishbone.
Insert new wishbone.
Put bolts in subframe but dont fully tighten.
Line up ball joint in the hub and jack that end up into the hub.
Look closely into the hub hole. The ball joint has a slotted section that the bolt will fit in. If the ball joint is not in enough it wont fit. If the ball joint is in too much it wont fit either.
Refit hub bolt
Refit wheel
JOB IS A GOOD ONE
