Latest: Beduff1977
Overall: 17134
Online Now [593]:
Visitors: 592
Today: 44273
Total: 108380689
Forums › The Car › 206 Talk › Coilovers or spring, uprating mine, help
PostPosted: Fri Jul 22, 2011 2:26 am Up
to be fair, if you go for coilover at least go for bilstein B14
PostPosted: Fri Jul 22, 2011 2:29 am Up
JE_180 wrote:
I have heard that spax are a hard setup though, I kind of like a firm suspension setup if I'm honest, if it's soft it doesn't make me think it's sporty and would handle well.
it is easy to setup the suspension to have "hard" ride without changing the spring Laughing
Callum206
PostPosted: Fri Jul 22, 2011 2:30 am Up
Okay to be fair my shocks are on the hardest setting and the coilovers on the front are wound down almost max i should be expecting a solid ride.
JE_180
PostPosted: Fri Jul 22, 2011 2:33 am Up
B14's are way overpriced. Anything from KW/Weitec/AP are supposed to be very good, the only ones I've tried out of those are KW's and I was very impressed.
drunknmunky
PostPosted: Fri Jul 22, 2011 2:46 am Up
I have had AVO on mine since august last year and cant fault them they have been awesome for me although someone else on here had nothing but problems with them so Confused
PugJH
PostPosted: Fri Jul 22, 2011 3:24 am Up
I suppose the word i was looking for is 'firm'
so not solid or soft. Just the right tightness Smile
WIP: Black 1.6 16v XSi
Beauté Noire
JE_180
PostPosted: Fri Jul 22, 2011 3:38 am Up
lmao. I have a dirty mind...
PugJH
PostPosted: Fri Jul 22, 2011 3:40 am Up
tbh i thought the same when writing it so its all good :D.
can't beat a bit of firm bounce, each to there own tho if callum likes a rock hard ride Wink
Beauté Noire
Seb
PostPosted: Fri Jul 22, 2011 3:41 am Up
Staff - Seb
You guys do know that it's the springs that affect the ride, you can probably get softer springs if you really want....
Callum206
PostPosted: Fri Jul 22, 2011 3:43 am Up
What do you mean by softer springs ?
Callum206
PostPosted: Fri Jul 22, 2011 3:44 am Up
Embarassed
JE_180
PostPosted: Fri Jul 22, 2011 3:48 am Up
Eibach ones lol Smile
Seb
PostPosted: Fri Jul 22, 2011 3:49 am Up
Staff - Seb
It's the spring that denotes how stiff the ride itself is for the most part, the dampers really only come into play when they're being properly compressed.
Springs are measured by poundage, for example I have 425 fitted on the front of my car and 475 on the rear, fitting a lower poundage spring will give you a softer ride. It's how much is required to compress the spring by 1 inch.
So a 100lb spring will require 100lbs to compress it by an inch, a 400lb spring, will require, surprise surprise, 400lbs to compress it one inch! Hence why lower poundage springs are softer as they compress much easier.
PostPosted: Fri Jul 22, 2011 3:52 am Up
this is true.
however a weak spring with a hard damper will give you a very stiff ride too.
PostPosted: Fri Jul 22, 2011 3:55 am Up
Confused
KW Variant 1 are same price or slightly higher than B14....
Page 2 of 3
