Latest: lio94
Overall: 17181
Online Now [276]:
Visitors: 275
Today: 36191
Total: 141903325
Forums › The Car › 206 Problems › squeeking and uneven wear front tyres!
kit325
PostPosted: Fri Jul 22, 2011 7:21 am Up
Both of my front tyres are currently wearing out outside edges, Camber out? . It make squeeking noise like braking hard when turning to sharp corner especially when its rain. Steering is horrible when on uneven surface and front absorbers been change few months ago.
Just wonder if anyone got any idea what it is? Many thz.
kit
-Dave-
PostPosted: Fri Jul 22, 2011 7:22 am Up
Trade Rating: +36
Tracking, Balancing, Are the usual thing's to check first.
Ex 206 Owner.
craigdmjv
PostPosted: Fri Jul 22, 2011 7:25 am Up
this sounds like what happened to my nieces seat ibiza hers was very low and she took it to a garage and they said shes lucky the wheel didnt come off lol maybe that was to make her part with her money but id get it checked
PostPosted: Fri Jul 22, 2011 8:50 am Up
Wear on the outside of your tyre's indicates theyre toeing in.
Big_Rich180
PostPosted: Fri Jul 22, 2011 9:22 am Up
Could it not be that they are underinflated?
kit325
PostPosted: Fri Jul 22, 2011 10:52 pm Up
The tyres are at normal pressure 32, only wearing out on outside edges ofboth front tyres and the steering control on bumpy road is s**t!
kit
PostPosted: Sat Jul 23, 2011 2:23 am Up
looks like you got too much toe out.
get the alightment check first
PostPosted: Sat Jul 23, 2011 3:00 am Up
To much toe out would wear the inside of the tyre.
As he's tyres have wear on the outside it's toe in that could be the problem.
PostPosted: Sat Jul 23, 2011 4:04 am Up
oh yeah. my bad Smile
DeadEyePaul
PostPosted: Sat Jul 23, 2011 5:19 am Up
As mentioned above, could be tracking could be balancing or even a part of
The suspension that needs replacing. I got an idea your tie rod ends need doing (would explain the outside tyre wear) or drop links(do you hear knocking on bumpy roads?)
kit325
PostPosted: Sat Jul 23, 2011 10:40 am Up
Drop links being change together with arb bush and absorbers. How to check if tie rod ends need replacing? the rubber bush on it seems alright.
kit
