Online Now [327]:
Visitors: 326
Today: 13950
Total: 138693233
Forums › The Car › 206 Problems › Can't understand why my battery has gone flat again :(
karimali831
PostPosted: Fri Jul 22, 2011 2:08 pm Up
After returning to my car, I turned on the stereo then locked the doors and noticed the stereo turned off and on again. I though, Oh s**t... here we go again and *click click click* when I attempt to run the engine.
I have noticed it has occurred twice while using this 75w inverter to charge my laptop:
www.homebase.co.uk/web...3EINVERTER
could this be the reason?
my second question is, when I charge the laptop via the inverter while engine is on, smoke starts to show up seconds later but I have had no problems charging it for an hour while engine was off... I was told I can use the inverter for charging laptops anyway...
any thoughts on this please?
206 GTI 180
PostPosted: Fri Jul 22, 2011 2:10 pm Up
75watts will be the MAX. Whats the constant?
karimali831
PostPosted: Fri Jul 22, 2011 2:16 pm Up
does that mean peak power? I can only provide you the details from the link, that's all I know about it.
206 GTI 180
PostPosted: Fri Jul 22, 2011 2:17 pm Up
You will have max/peak and then constant/rms
For example it might be 500 max, but only 150 rms
karimali831
PostPosted: Fri Jul 22, 2011 2:22 pm Up
That I do not know but obviously will avoid it from now on.
If the answer is I need a higher output watts inverter then it's fine.
206 GTI 180
PostPosted: Fri Jul 22, 2011 2:25 pm Up
Well you'd have to check the RMS, and the wattage of your laptop
karimali831
PostPosted: Fri Jul 22, 2011 2:40 pm Up
Yes will get this checked out, thanks for help! Smile
206 GTI 180
karimali831
PostPosted: Fri Jul 22, 2011 6:26 pm Up
I thought a battery could last up to 6 hours when engine is off! Embarassed
I used/charged laptop 1-2 hours while engine was off... at least I know now.
Oopz! Laughing
206 GTI 180
Ali_H
PostPosted: Sat Jul 23, 2011 4:28 am Up
It depends what you're running, I never charge anything when the engine is off, or run the stereo for that matter.
kurtis wrote:
sillyhilly
PostPosted: Sat Jul 23, 2011 4:42 am Up
Hang on, it's doing it only when you charge your laptop and you see smoke?! From where?! Am I getting the wrong end of the stick here?
Hi Mikey Smile
deanparkr
PostPosted: Sat Jul 23, 2011 6:02 am Up
I am also curious of the smokes location!
2002 1.4LX
karimali831
PostPosted: Sun Jul 24, 2011 1:14 pm Up
The smoke is coming directly off the AC car cigarette adaptor of course Smile
It overheats too much when engine is on.
206 GTI 180
