Online Now [553]:
Visitors: 552
Today: 70715
Total: 105512703
Forums › The Car › 206 Problems › Airbag fault
Airbag fault
kieron
PostPosted: Sat Jul 23, 2011 8:53 am Up
Today ive had the the car scanned for a airbag fault and it came up as
Driver module permanent trigger open fault circuit
could anyone advice the fault to look for / replace
cheers kieron
Account suspended
ukskater01
PostPosted: Sat Jul 23, 2011 10:36 am Up
I had this, I had to take my glovebox out (there's a how to) Then cut the plug out and solder the wires together (disconnect the battery for at least 10 mins before and follow soft boot procedure if your car is multiplexed).
The only thing is my code said passenger open circuit, I think there is a plug behind the ashtray that would be for the drivers I think. It could also be the drivers side seatbelt pre tensioner
Hope this helps
PostPosted: Sat Jul 23, 2011 4:05 pm Up
Either COM2000 if your MUX or horn spool if your pre
Or maybe the orange connector in the fuse box
