Latest: jackrox1992
Overall: 17186
Online Now [1008]:
Visitors: 1006
Bots: 2
Today: 218263
Total: 147920491
Forums › The Car › 206 Talk › Cruise control
Cruise control
Forum Index › 206 Talk
Go to page Previous  1, 2, 3 ... 19, 20, 21 ... 34, 35, 36  Next
wagsy206
PostPosted: Sat Mar 06, 2010 3:16 pm Up
lol
i know grahams probably talking about Matt at ecosse.
Wagsy206
old post count: 5000+
Team: Honda Accord
wagsy206
PostPosted: Sat Mar 06, 2010 3:37 pm Up
www.howard-may.co.uk/1...on*id*val*
dont know if this information is relevant to the topic at hand.
www.howard-may.co.uk/1...18535.html
Wagsy206
Team: Honda Accord
Brian
PostPosted: Sun Mar 07, 2010 1:39 pm Up
Trade Rating: +31
wagsy206 wrote:
lol
He and Rab Elliot who are both peugeot machines.
It's a shame that this isn't terribly straight forward as we'd hoped for! Sad
wagsy206
PostPosted: Sun Mar 07, 2010 1:46 pm Up
i knew it had to be £240 from the Garage on Hamilton Road for a reason. lol.
but matt and rab are awesome guys. and obviously theyre all there and a bit more when it comes to that.
Wagsy206
Team: Honda Accord
Lecktorious
PostPosted: Sun Mar 07, 2010 1:58 pm Up
Trade Rating: +59
£240 is still kinda cheap going by how much aftermarket kits are to have fitted and set-up though.
Wonder if they actually CAN do it though, would need to ask exactly what it is they do though as they only need to configure the BSi and ECU on my car as the stalk is already fitted...
'98 Nile Blue 306 GTi 6
wagsy206
PostPosted: Sun Mar 07, 2010 2:23 pm Up
might be worth giving them a call. but obviously state that you have the stalk and clutch contact switch, and all you need done is the configuration.
the technician from the london road garage, his name is Colin. lol. ill probably give him a call next week.
Wagsy206
Team: Honda Accord
skard
PostPosted: Sun Mar 07, 2010 2:25 pm Up
i was playing in PP2000, went into the com2000 unit and tested every button for operation.
so vol up. vol down, indicators, lights, horn blah blah - every button was detected when pressed. it even did this with the CC unit, so the presence of the stalk in the com unit is detected.
it seems it's only a bawhair off being completely setup but can't see what is blocking CC out on the road in a 206?
i also noticed that my cluster has no diagram for CC.
it'd be nice to know if we're p**sing in the wind.
wagsy206
PostPosted: Sun Mar 07, 2010 2:30 pm Up
skard are you talking about servicebox diagrams?? i stuck my VIN in, and it showed the CC stalk to the side of the COMM2000, but there was nothing in the list to the side.
but when i used the search bar, and typed 6242Z8 in with the VIN filter ON, it did come up stating there was a diagram with it, so it IS optional for my car.
maybe you should check that way??
Wagsy206
Team: Honda Accord
skard
PostPosted: Sun Mar 07, 2010 2:43 pm Up
no, PP2000.
you can check sensors - it physically detects the stalk is in installed in the com2000 and when the buttons are being pressed.
wagsy206
PostPosted: Sun Mar 07, 2010 2:45 pm Up
but it just doesnt show anything on the installed diagrams?
well as graham says, its more than likely a BSI configuration Sad
Wagsy206
Team: Honda Accord
skard
PostPosted: Sun Mar 07, 2010 2:46 pm Up
i see what you mean wagsy about servicebox. what i meant was if you shine a backlight into your speedometer you will not see the CC symbol, but i'm unsure if that's normal for pugs seeing as the stalk tells you if it's on or off.
Lecktorious
PostPosted: Sun Mar 07, 2010 2:55 pm Up
Trade Rating: +59
It can be set-up fine in the BSi, its in the ECU that you cannot change the status of CC from 'absent' to 'present'.
An ECU update won't do any good either as I already have the latest version.
Unless these Dealerships quoting £200+ know something we don't and can fully set it up it looks like a no go.
wagsy206
PostPosted: Sun Mar 07, 2010 2:56 pm Up
yeah, cause the display comes up on the odometer. where it tells you the milage your car has done, it shows you on that. if your on the motorway and switch on the cruise control, it says = CC 70 basically showing that cruise control is active and set at 70mph
but pugs are just wierd cars, lol. nothings ever easy with them.
Wagsy206
Team: Honda Accord
mattievrs
will the cc activate whilst stationary? I wonder if it has to be active whilst you turn it on via pp2000 so it "sends" it some values/parameters?
Also have you tried to switch it on through pp2000 with and without the engine running?
NO LONGER ACTIVE ON THE FORUM
wagsy206
PostPosted: Sun Mar 07, 2010 3:00 pm Up
you cant activate it while its stationary. you have to be doing at least 50mph in 4th or 5th gear.
you could probably set the limiter while stationary. but not the CC
Wagsy206
Team: Honda Accord
Page 20 of 36
