Online Now [100]:
Visitors: 100
Today: 15924
Total: 138751275
Forums › The Car › 206 Problems › Screw that holds the rear lights in place is stuck
craigy00craig
PostPosted: Thu Jul 28, 2011 1:27 am Up
That plastic screw that you un do to get the rear lights out is stuck, its really not moving at all. Tried using plyers to losen it but it wont budge. Anyone had this before? Not sure what i can do to remove it Sad
Progress Threads:
PostPosted: Thu Jul 28, 2011 1:30 am Up
I think a 17mm ring spanner will fit over it, I have used that method before and it works
juanfernandes
PostPosted: Thu Jul 28, 2011 1:40 am Up
Yeah I had to use a spanner on my old car. But be careful as it may break.
Quote::
Jay794
PostPosted: Thu Jul 28, 2011 2:05 am Up
Spanners? Torx FTW and a bit of grease or WD40
PostPosted: Thu Jul 28, 2011 2:09 am Up
Heat it up with a blow torch... and post a video Razz
Good shout on the 17mm socket by the way. Got the same issue on the 206 I service.
PostPosted: Thu Jul 28, 2011 2:10 am Up
Torx wouldnt work, you need to use a ring spanner so it can go over the nut on the screw.
mattievrs
PostPosted: Thu Jul 28, 2011 2:12 am Up
And make sure youre undoing it the righ way aswell. Its easy to tighten it as its backwards
NO LONGER ACTIVE ON THE FORUM
craigy00craig
PostPosted: Thu Jul 28, 2011 2:35 am Up
Im confused... how will a spanner or socket fit the plastic thing? Its not shaped like a nut....
Progress Threads:
Kersh
PostPosted: Thu Jul 28, 2011 2:37 am Up
because it will slot over the top quite neatly
Member number: 36
PostPosted: Thu Jul 28, 2011 2:41 am Up
Push the light in as well when you try and losen it and it will make it a hell of a lot easier.
And get mole grips, don't see it not working then
Kersh
PostPosted: Thu Jul 28, 2011 2:49 am Up
he has a point, its only plastic.. hit the gym Smile
Member number: 36
craigy00craig
PostPosted: Thu Jul 28, 2011 2:53 am Up
Cheers lol my fingers were almost bleeding trying to get it undone last night!!
Progress Threads:
Jay794
PostPosted: Thu Jul 28, 2011 3:17 am Up
Sorry I meant Socket, I have a socket set that comes with a load of Torx bits, a socket set would do it
Antknee
PostPosted: Thu Jul 28, 2011 4:31 am Up
Lecktorious
PostPosted: Thu Jul 28, 2011 6:20 am Up
Trade Rating: +59
Man up.
'98 Nile Blue 306 GTi 6
