Latest: Stu-mill
Overall: 17131
Online Now [310]:
Visitors: 309
Today: 5840
Total: 104814708
Forums › The Car › 206 Problems › are 138 gti and 180 gti top coolant hoses the same fitment?
PostPosted: Sat Jul 30, 2011 4:29 pm Up
as title anyone know if they are the same i know the bottom ones are different but the top looks similar to me?
PostPosted: Sat Jul 30, 2011 4:30 pm Up
same. even 2.0HDi use the same top coolant hose.
PostPosted: Sat Jul 30, 2011 4:31 pm Up
sweet cheers mate Smile
PostPosted: Sun Jul 31, 2011 4:54 am Up
Think ive got some that you can have for the cost of postage unless ive thrown them
PostPosted: Sun Jul 31, 2011 9:44 am Up
its just so i can order a red silicone one to match the other red bits under my bonnet Cool
thanks for that though mate Wink
PostPosted: Sun Jul 31, 2011 11:06 am Up
Are you getting one from Samco?
PostPosted: Sun Jul 31, 2011 11:55 am Up
have sent spoox an email as there kit is a lot cheaper so hopefully they will sell me the top one on its own if not il try and get one direct from samco
was going to see if i sent a set of 180 hoses weather samco will make some up but i think that will be epically expensive Crying or Very sad
PostPosted: Sun Jul 31, 2011 11:58 am Up
I waited 8 weeks for Samco to make some standard blue hoses for the 206. If you want red then be prepared to wait even longer.
PostPosted: Sun Jul 31, 2011 11:59 am Up
really that sucks! cheers for the heads up Smile
