Latest: Kifi69
Overall: 17183
Online Now [369]:
Visitors: 368
Today: 40698
Total: 143589427
Forums › The Car › 206 Problems › Speed sensor Which wire is which?
macj
PostPosted: Sun Jul 31, 2011 6:47 am Up
On the transmission of a BE4 gearbox from a GTi, anyone know the layout and function of the three wires. I am trying to make a digital processor for stage distance and time to work from one.
PostPosted: Sun Jul 31, 2011 7:05 am Up
The MM 4.8P or the MM 4MP2 ecu?
macj
PostPosted: Sun Jul 31, 2011 7:12 am Up
Its all on stand alone ECU. I have a bare canvass mate. The rally trip computor needs a pulse signal. It can input 5volts to the sensor and has a wire from the pulse terminal and a -ve wire. The problem is I can either use an old ABS sensor on one wheel to feed it a pulse or use the gearbox sensor. I just dont want to fry anything
PostPosted: Sun Jul 31, 2011 7:23 am Up
Pin 1 - CM32M - voltage - engine fuse box
Pin 3 - 6739 - vehicle speed info
Pin 2 - MM01A - earth
macj
PostPosted: Sun Jul 31, 2011 7:26 am Up
nice one mate.... now how do I know which is pin1 Shocked
I assume pin 3 is middle
PostPosted: Sun Jul 31, 2011 7:35 am Up
If you look very closely there will be numbers
nah pin 3 is at the end, i just listed them in the order that I read them off the diagram Laughing
normally Pin 1 is to the right
macj
PostPosted: Sun Jul 31, 2011 7:40 am Up
looks like I need to borrow some glasses then.... cheers for the help bud. Hope the hangover is better Cool
PostPosted: Sun Jul 31, 2011 7:42 am Up
I'll have a look to see if I have one in the shed to see if I can see them.
Dunno if I left it on the engine when I sold it or not
macj
PostPosted: Sun Jul 31, 2011 7:46 am Up
I spent about an hour trying to find a 3 pin plug for it.... I junked the whole loom when I built the car so will be off to the scrappy tomorrow
PostPosted: Sun Jul 31, 2011 7:47 am Up
Does it look like this?
macj
PostPosted: Sun Jul 31, 2011 7:53 am Up
nope.... thats the cable drive unit I think, looks like this
macj
PostPosted: Sun Jul 31, 2011 8:04 am Up
And now I can see the numbers Laughing
PostPosted: Sun Jul 31, 2011 8:14 am Up
and a slightly cleaner version.
PostPosted: Sun Jul 31, 2011 8:19 am Up
Razz
macj
PostPosted: Sun Jul 31, 2011 9:56 am Up
Yes Ed..... its a bit grubby round there Embarassed
