Posted: Sun Jul 31, 2011 8:00 am |
Hi all,
I have a 2001 1.4lx (206) and the OEM head unit that came with the car isnt working (no power though it does illuminate with the dash funnily enough!).
I bought a Pioneer HU from eBay (which was sold as in perfect working order) and installed it yesterday using the supplied ISO adapter. Even after swapping the red and yellow wires, there is no power at all going to the head unit.
I've swapped the 15A radio fuse along with the cigarette lighter fuse as i noticed the last one had blown, though not sure what else could be wrong?
I know its possible that the new HU may also be fried though i haven't got another car to test it with just yet..
Has anyone heard of this kind of strange problem before? Ive trawled the forums though the main issue seems to only ever be the loss of memory in the HU rather than a complete loss of power
Cheers, Blake.
| Pug 206 1.4 LX year: 2001 | |
Posted: Sun Jul 31, 2011 9:36 am |
Wire correctly in at the back of the headunit?
Mine fell out on the old kenwood
| Team Impossible Possible
Posted: Sun Jul 31, 2011 11:46 am |
I had something similar when i swapped my headunit the memory wire just died (no power was even coming to it even from the plug which the radio loom connects to), it would make a whirring noise and then do nothing, in the end i had to wire a new memory wire straight from the battery.
You should check the voltages from the memory wire and the ignition lead, memory lead is 12v, and ignition is 12v when turned into the first position and onwards. If memory recalls thick blue wire is the ignition lead and i think the memory is white, i can't remember 100% someone will have to confirm.
| Now a 2010 Renault Megane Coupe owner | |
Posted: Mon Aug 01, 2011 6:35 am |
Thanks for the replies guys; borrowing a multimeter tonight to check the light blue and white cables for 12v so ill update here once done..
Posted: Sat Aug 06, 2011 11:29 am |
Very relieved to say all ok now. Bought a car to ISO adapter and an ISO to pioneer adapter and it turned straight on!
Posted: Sat Aug 06, 2011 6:08 pm |
the car should have had an iso block as standard fit anyway?
| Drive Smarter Not Faster! | |
Posted: Sun Aug 07, 2011 10:31 am |
Yeah im not too hot on electrics and wiring but the standard loom was ok after testing with a multimeter, so i bought a new ISO adapter along with a new pioneer to ISO harness and fitted those with good results.
It could have just been a faulty pioneer to ISO harness all along!
