Latest: tebas93089
Overall: 17179
Online Now [227]:
Visitors: 226
Today: 28416
Total: 137800457
Forums › The Car › 206 Problems › Clutch and Brake Switch Problems
southwestchap
PostPosted: Mon Aug 01, 2011 4:38 am Up
Hey all...
I've had my car plugged into Peugeot planet a couple times now over the past few months whenever ive had the chance to, and everytime i read the codes it always comes up with clutch and brake switch fault....
ive had the clutch switch out and took it apart and cleaned it and made sure the pedal is coming up to the switch ok...but still seems to come up as a fault....also the brake light switch is where its supposed to be...
any ideas...
car drives fine and that but just annoying to keep bringing up the faults when i cant see anything wrong....
sx206
PostPosted: Mon Aug 01, 2011 5:32 am Up
most times the reading of the ecu is a waste of time,no fault found is usualy the case anytime mine was read,last time was coilpack,running like a dog but no fault showing in ecu.if your car is fine why bother. Smile
206
