Online Now [99]:
Visitors: 98
Today: 6029
Total: 143074548
Forums › The Car › 206 Problems › strut bearings, quick question
Lewis1592
PostPosted: Tue Aug 02, 2011 10:35 am Up
can i just get away with replacing the bearings or have i got to go for the full mount?
as you can see it can mean many precious pennies saved.
bearings: www.ebay.co.uk/itm/PEU...3ef60d4529
mounts: www.eurocarparts.com/s...n-mounting
many thanks
lewis
2001, 206 1.4 lx first car Very Happy
PostPosted: Tue Aug 02, 2011 10:51 am Up
it depends on what is damaged on your old stuff....
Lewis1592
PostPosted: Tue Aug 02, 2011 10:57 am Up
seems to just be making some unhealthy noises at low speeds. doesnts affect handling or anything. but i guess u cant really tell until u take it all off and have a look.
PostPosted: Tue Aug 02, 2011 11:09 am Up
looks to me the top mount rubber itself.
as the bearing does affect handling
PostPosted: Tue Aug 02, 2011 11:33 am Up
Unless it's 10 years old and worn out.
Lewis1592
PostPosted: Tue Aug 02, 2011 11:35 am Up
ha yeah ill probz just get the mount and be done with it
Do the bearings too.
Lewis1592
PostPosted: Tue Aug 02, 2011 11:40 am Up
comes with bearings no?
www.eurocarparts.com/e...amp;000346
PostPosted: Tue Aug 02, 2011 11:42 am Up
Those are the bearings in the picture yes.
doughboy5
PostPosted: Tue Aug 02, 2011 2:05 pm Up
jumpin in on your post
i have a 51 plate gti only got 40k on it would mine need doing at some point and would it help with the handling not that i have noticed anything wrong with it. i have no idea when it comes to all the suspension stuff and that. lol
206 GTi
00budham00
PostPosted: Tue Aug 02, 2011 2:10 pm Up
Go scrap yard i got a really good set for a Fiver
JazzyB
PostPosted: Tue Aug 02, 2011 2:15 pm Up
Yes, the smaller part is your bearing,under that the upper spring seat.The rubber part is your upper mount in plate.
I've used the same kit on my car.Well the cc one Laughing
206 1.6 cc
Lewis1592
PostPosted: Tue Aug 02, 2011 3:44 pm Up
So I'm guessing that it's a case of replace the bearing in the spring seat. Then placing the upper mount plate onto. As I'm guessing those 3 bolts are the ones I can see under the bonnet. And in this picture it's upside down.
