Latest: tbafonso
Overall: 17130
Online Now [59]:
Visitors: 58
Today: 13527
Total: 103835850
Forums › The Car › 206 Problems › Windscreen wiper Problem
Nizmo
PostPosted: Thu Aug 04, 2011 4:24 am Up
Hi guys
Hope this is a easy one for you. My windscreen wipers work ok. When i turn them on they go from bottom of windscreen to top no problem. The problem i have is when i turn them off. They rest about 2"'s from the bottom. When i then turn them on again they go down before they go up. As if there still finishing the last cycle. ( If that makes sence).
Has anyone else had this? If so how did you fix it?
Also need some wiper blades as someone has put the wrong size on. Anyone know what size wipers i need.
Thanks for reading Smile
Pug 206 1.9d
QuArTz
PostPosted: Thu Aug 04, 2011 7:26 am Up
Trade Rating: +16
Sizes are 18" and 22" on the front..
not sure bout the cycle problem.. sorry
Nizmo
PostPosted: Thu Aug 04, 2011 7:35 am Up
Wicked. Thx buddy Smile
Pug 206 1.9d
MrrNoName
PostPosted: Thu Aug 04, 2011 8:49 am Up
the sizes are different depending on the year of 206, mine for example has 22" on both wipers and they are ok. I also know some have 21" + 22" on as i believe the 21" blade fits better on the drivers side, (due to the high curvature of the corner of the windscreen a 22" blade lifts off at the edge a tiny bit on the drivers side) but this doesnt cause any issues
originally mine also had the incorrect wipers on, and it left a chunk that was not "wiped" at the top of the passenger side
PostPosted: Thu Aug 04, 2011 8:51 am Up
Older ones like mine have 19" an 26"
Nizmo
PostPosted: Fri Aug 05, 2011 5:59 pm Up
mines a 1999. I've looked everywhere and everyone says diff sizes. Im just not sure lol
Pug 206 1.9d
MrrNoName
PostPosted: Sat Aug 06, 2011 4:13 am Up
measure your current wipers, if they are the incorrect size use a tape measure to work out what would be the correct size. Just place it over the glass and see what length covers the window correctly, takes 2 seconds Razz
i cant tell you about 1999 but with 2001 its 22"/21"
