Latest: tebas93089
Overall: 17179
Online Now [110]:
Visitors: 109
Today: 27133
Total: 138129010
Forums › The Car › 206 Problems › Throttle squeaking? Help!
Norvvv
PostPosted: Wed Aug 03, 2011 8:02 am Up
When I engage or disengage the accelerator pedal there is a short sharp squeak, seems to be from the back end of the car?
Ps, have searched, just no probelms seem to be the same :/
Big_Rich180
PostPosted: Wed Aug 03, 2011 8:04 am Up
Is this squeek only while moving or any time you rev the car?
Norvvv
PostPosted: Sat Aug 06, 2011 9:47 am Up
It's literally just a short sharp squeak as I engage or disengage the throttle ..
2001 1.4lx
PrePlexed 5 door.
PostPosted: Sat Aug 06, 2011 9:49 am Up
does it squeak when you are stationary and when the engine is off?
Mine has a small squeal and it's the connection between the pedal and cable i think, just can't be bothered to get head under dash yet
Norvvv
PostPosted: Sat Aug 06, 2011 9:57 am Up
I don't think it makes the noise with the engine off or in neutral when it's on. I know it sounds weird but could it be something to do with the back suspension as that squeaks when going over big bumps or taking corners fast..
2001 1.4lx
PrePlexed 5 door.
Okezza180
PostPosted: Sat Aug 06, 2011 10:43 am Up
Hey, I think i have the same problem, touching the acc pedal v slightly and the car squeaks. I asked the guy who did my MOT and he said its probably is the exhaust manifold. Apparently its on springs to accommodate movement, and thats what is squeaking. I think he said replacing the springs fixed the noise. I need to sort this out too before I sell the car.
Hope this helps.
Blue 180
Norvvv
PostPosted: Thu Aug 11, 2011 10:03 am Up
Ok thanks for that, odd seeing as I got a whole new exhaust about a month ago. You'd of thought they would change the springs! Ha.
2001 1.4lx
PrePlexed 5 door.
