Online Now [477]:
Visitors: 476
Today: 46321
Total: 145008780
Forums › The Car › 206 Talk › Milage reading
Milage reading
Forum Index › 206 Talk
karimali831
PostPosted: Sat Aug 06, 2011 6:17 pm Up
Hey guys
Just wanted to get something clear... there are two readings, the overall reading I'm assuming is milage but what about the other reading? kilometers or miles or??
I really hope it is mileage, just tested how far it goes with £10 and around 80 miles. Is that bad? Surely 80 kilometres for £10 is just awful!
Thanks Smile
206 GTI 180
Matt
PostPosted: Sat Aug 06, 2011 6:21 pm Up
Trade Rating: +32
Other reading on the speedo?
karimali831
PostPosted: Sat Aug 06, 2011 6:31 pm Up
She's almost done 100k miles Sad
206 GTI 180
PostPosted: Sat Aug 06, 2011 6:33 pm Up
Your possibly talking about the service indicator, if thats the case then it just tells you roughly when your due a service.
PostPosted: Sun Aug 07, 2011 2:52 am Up
Think about it logically, £10 is less than 2 gallon, so if you are getting 35-40 miles per gallon or kilometer (not sure which as you mention them both in the OP) and depending on the type of driving you are doing, then it might be OK.
On a new model 2003 1.1, you could only expect 44mpg in mixed driving.
Giving the car a service and putting a full tank of shell v-power in will increase economy.
If the second reading comes on when you turn the ignition on, then goes off after 5 seconds, it's more likely the service indicator.
Edit. dug these out so they may help
Taken from the driver pack
PostPosted: Sun Aug 07, 2011 3:26 am Up
You are on about the trip meter. All are in Miles if the car is from the UK
meady
PostPosted: Sun Aug 07, 2011 6:27 am Up
Trade Rating: +45
80 miles is good for a tenner and it will be the trip distance not overall mileage
TEAM - I HATE FACEBOOK Smile
AshH
PostPosted: Sun Aug 07, 2011 6:34 am Up
Laughing Mines 135k .. And still going strong Wink
Team - 180
Team - ATM!!!
karimali831
PostPosted: Sun Aug 07, 2011 7:10 am Up
Thanks Smile
I believe I can do 10 miles for every litre, around £1.35 for every 10 miles not bad, but with countries at around 67p a litre... it would feel incredibly cheap! Smile
206 GTI 180
bigdipper
PostPosted: Sat Mar 30, 2013 3:08 pm Up
Hi I`m a new member.I have just purchased an old (1998) 206 to keep me mobile after my last car was written off.I am quite happy with it but the mileage indicator isn`t showing,It apparently went off when a fuse blew while the previous owner was going on holiday.she is a young lady with no mechanical understanding at all.I dont know what other facilities were affected so I haven`t a clue as to which fuse to replace.I don`t know how critical it is, pther than an inconvenience but it got through it`s last M.o.T with the mileage stated as "not displayed".Has anyone any ideas on how to restore it,please?
PostPosted: Sat Mar 30, 2013 4:09 pm Up
Check the bulb behind it.
PostPosted: Sat Mar 30, 2013 6:49 pm Up
Yes.
That bulb is always the first to go because it's on all the time, even with headlights or sidelights off.
Easy fix once you get behind the dials.
bigdipper
PostPosted: Sun Mar 31, 2013 7:25 am Up
Thanks Macca, I hope it proves to be that simple.
bigdipper
PostPosted: Mon Apr 01, 2013 6:20 am Up
Since receiving the reply re bulb from macca1411(thanks again macca) I haave since learned that the problem first occurred when the previous owner was going on holiday using a satnav plugged into cigar lighter.The satnave went down so she drove to neares garage who diagnosed a blown fuse. They replaced the fuse which brought the satnav back to life so they continued on their way.It seems the mileage indicator failed at the same time,so, as everything else seems to be working it lokks as if the bulb blowing may have caused the fuse to blow.Can anyone tell me the type of bulb required to light up the mileage indicator as I have to go quite a long way to buy said bulb and would prefer to purchase one before dismantling the facia.The car is 1998 S reg 206 LX 1.1 5 door hatchback.Thanks ,in anticipation.
