Latest: tebas93089
Overall: 17179
Online Now [111]:
Visitors: 110
Today: 3681
Total: 138311985
Forums › The Car › 206 Problems › Front passenger lock on non-central locking must use key?
FridgeRaider
PostPosted: Sun Aug 07, 2011 3:34 am Up
Hey.
My sister has just got herself a lovely T-reg 1.1 206. All seems well with it, though there is one little niggle.
The car doesn't have central locking, which is fine, but the front passenger door stalk won't lock when you have the door open (i.e. you have to close it and lock with the key). Is this just a thing with the 206, or is there something you can change to make it work?
Apologies in advance if this has been answered...my search fu was low.
As effective as a cat flap in an elephant house.
PostPosted: Sun Aug 07, 2011 3:38 am Up
alot of car do it that,
none of the cars/vans i use dont do it,
namgaj
PostPosted: Sun Aug 07, 2011 3:44 am Up
On some cars if you lift the exterior handle then lock it (with the handle still lifted) then shut it while still holding the handle up, it works. I never tried it on a pug but it works on other cars Smile
4.0 V8 S-Type Jaguar
craigdmjv
PostPosted: Sun Aug 07, 2011 4:49 am Up
or you could get the passenger to get out first, lean over then lock their door then get out your self simple
PostPosted: Sun Aug 07, 2011 8:14 am Up
Its designed like that to stop idiots locking the keys in the car.
FridgeRaider
PostPosted: Sun Aug 07, 2011 8:17 am Up
Fair enough, thanks for the suggestions all. I think the let the passenger get out first plan should work fine.
PostPosted: Sun Aug 07, 2011 8:20 am Up
Be kind to your sister & see if you can retrofit her some central locking.
Plenty of 206's in the scrapyards to get bits from Wink
macj
PostPosted: Sun Aug 07, 2011 8:54 am Up
good idea mate but then you need to find a coathanger when you forget
PostPosted: Sun Aug 07, 2011 9:14 am Up
Should just lock / unlock the passenger door when the drivers door is locked / unlocked, should still be virtually impossible to lock the keys in the car.
PostPosted: Sun Aug 07, 2011 10:10 am Up
Not hard to get into the car even if you do lock your keys in the car Laughing
PostPosted: Sun Aug 07, 2011 11:37 am Up
If you know what your doing Wink
Not everybody has the same skill level as us Laughing
