Latest: Stu-mill
Overall: 17131
Online Now [309]:
Visitors: 308
Today: 46552
Total: 104682799
Forums › The Car › 206 Problems › fairly loud rattling noise at idle / low revs
arwright16
PostPosted: Mon Aug 08, 2011 7:20 am Up
Hello everyone
I bought an X reg 206 1.9 diesel recently, and unfortunately it has begun to rattle at low revs. It osunds like it is coming from the front. I had another car that made this noise and it was a loose exhuast. However, having looked at it underneath I can't see that it is moving very much. The engine shakes a dair bit - is this normal? Could it be an engine mount, or where tehe xhuast connects nearer to the engine?
Many thanks for any help you can give
Kersh
PostPosted: Mon Aug 08, 2011 7:26 am Up
could be a heat shield
Member number: 36
arwright16
PostPosted: Tue Aug 09, 2011 11:29 am Up
okay, thanks - where should I be looking to see if the heat shield is loose? What will it look like?
thanks again
