Latest: jackrox1992
Overall: 17186
Online Now [536]:
Visitors: 534
Bots: 2
Today: 53342
Total: 148433308
Forums › The Car › 206 Talk › any ideas on cheap and easy mod for my 206
Forum Index › 206 Talk
dafdavies
PostPosted: Mon Aug 08, 2011 3:20 pm Up
any ideas????
Team: If you cant find the tool you need make one
jimjam19927
PostPosted: Mon Aug 08, 2011 3:22 pm Up
www.206info.co.uk/Foru...t+mod.html
Member: 685
I Over Use Smilies Razz
dafdavies
PostPosted: Mon Aug 08, 2011 3:25 pm Up
i cant do the b pillars on mine cuz there plastic right?
lmilligan
PostPosted: Mon Aug 08, 2011 3:47 pm Up
wheel arch extensions if you havent got the factory sp kit! set the car off nice Smile
dafdavies
PostPosted: Mon Aug 08, 2011 4:02 pm Up
Kool ill look it up anything to sprouse the interiour up
My car looks really tired as it is now
Dabamash
PostPosted: Mon Aug 08, 2011 4:04 pm Up
Staff - Daba
Should be able to remove the B pillar vinyl on any 206
mattievrs
read the link and youll find out if theyre plastic or not....... Confused
NO LONGER ACTIVE ON THE FORUM
dafdavies
PostPosted: Mon Aug 08, 2011 4:15 pm Up
Okay I jus wanted to be sure if I go taking them off and screw it up
mattievrs
PostPosted: Mon Aug 08, 2011 4:16 pm Up
Pull the vinyl off from behind the door to be sure its painted first, but they will 100% NOT be made of plastic, i can assure you of that! Laughing
What colour is your car?
dafdavies
PostPosted: Mon Aug 08, 2011 4:21 pm Up
Gray
mattievrs
PostPosted: Mon Aug 08, 2011 4:24 pm Up
yeah pull the vinyl off if its grey, itll look better.
dafdavies
PostPosted: Mon Aug 08, 2011 4:26 pm Up
Okay thanks pal anything I can do about the black bits on the bumpers the rear one faded
mattievrs
PostPosted: Mon Aug 08, 2011 4:41 pm Up
you can either spray them, clean and use back to black, use peanut butter or heat gun them. Search on youtube for the heat gun method Wink
dafdavies
PostPosted: Mon Aug 08, 2011 4:46 pm Up
Okay will do ill post some pics of it tomorrow and show how its going along
dafdavies
PostPosted: Tue Aug 09, 2011 7:09 am Up
m.facebook.com/home.ph...1312895302
