Latest: tbafonso
Overall: 17130
Online Now [297]:
Visitors: 296
Today: 29739
Total: 104561537
Forums › The Car › 206 Talk › air bag ecu,s were are they both located...
shell-vt
PostPosted: Tue Aug 09, 2011 11:45 am Up
Trade Rating: +46
im wanting my air bag ecu,s removed i know were one is but i beleve thair is two were is that one at, this should take the light of dash aswell yes....??????
for my track car...........
york 16,3
PostPosted: Tue Aug 09, 2011 11:48 am Up
think is in front of the gear stick, under the ash tray
shell-vt
PostPosted: Tue Aug 09, 2011 11:56 am Up
Trade Rating: +46
thort 180 had x2 ...dash light should go off aswell yes.......
york 16,3
PostPosted: Tue Aug 09, 2011 11:58 am Up
No, you need to turn the airbags off in the BSI
shell-vt
PostPosted: Tue Aug 09, 2011 12:01 pm Up
Trade Rating: +46
can you explain bsi please.........
york 16,3
PostPosted: Tue Aug 09, 2011 12:04 pm Up
Basically like the motherboard of your PC. It controls the whole electrics.
Rip the sound card out of your PC and its going to throw up a whole load of errors, you would have to remove the drivers.
Same principle when removing the Airbag ECU from the car
shell-vt
PostPosted: Tue Aug 09, 2011 12:08 pm Up
Trade Rating: +46
god you got me puzzled... so shall i leave it were it is then its not needed but lights on now since i replaced wheel seats...
york 16,3
PostPosted: Tue Aug 09, 2011 12:09 pm Up
The BSI is your cars brain Laughing
shell-vt
PostPosted: Tue Aug 09, 2011 12:11 pm Up
Trade Rating: +46
i,ll leave it then yer ...
york 16,3
PostPosted: Tue Aug 09, 2011 12:12 pm Up
What are you wanting to do?
Remove all the SRS system?
shell-vt
PostPosted: Tue Aug 09, 2011 12:20 pm Up
Trade Rating: +46
my car is a 206 gti 180 track car ive removed oem steering wheel and seats and fitted aftermarket ones, so i want to remove the srs system now as its not needed... also the light is now on so removing all this should also remove the light ...
york 16,3
PostPosted: Tue Aug 09, 2011 1:07 pm Up
Oh the joys of modern cars Laughing
shell-vt
PostPosted: Tue Aug 09, 2011 1:10 pm Up
Trade Rating: +46
yer love & hate
york 16,3
PostPosted: Tue Aug 09, 2011 2:14 pm Up
Should have just measured the resistance to the airbag ecu when it was functional and then you could have just fitted a resistor
Or just remove the ECU, and de-solder the SMD for the airbag light
PostPosted: Wed Aug 10, 2011 9:47 am Up
Airbag ecu under front ashtray.
Satellite sensor on each sill for the side & curtain airbags.
Remove airbag ecu & sill sensors, turn ALL airbags & seatbelt pretensions off in BSI configuration, airbag warning lights will go / stay off.
