Online Now [205]:
Visitors: 204
Today: 14288
Total: 104964648
Forums › The Car › 206 Problems › Replacing Blown Bulbs
PaddyC
PostPosted: Wed Aug 10, 2011 3:08 am Up
The first bulb that's gone is in the radio display dash, the centre bulb seems to have gone. How do you access the inside to replace the bulbs? (If one's gone, I'll just replace all three for convenience sake!)
The other bulb that's gone is the left hand side of the fan unit. How do I access that to change the bulb? Am I going to have to remove the dash to do it?
For both of these cases, where's the best place to get the replacement bulbs, is it Peugeot themselves or do places like Halfords do them? (It's easier for me to get to Halfords than Peugeot!) Are they cheap enough to buy? Thanks for any help! Smile
Peugeot 206 1.4HDI Style
PostPosted: Wed Aug 10, 2011 3:11 am Up
Pull the hood off the top of the display to gain access to the bulbs on top one.
To get to the heater display bulbs take the top same as above, and then remove centre console.
Harty
PostPosted: Wed Aug 10, 2011 3:27 am Up
yeah halfords do the bulbs for them, but i found that the air con control bulbs were harder to get access to as the rods for the circulation and stuff got in the way, i miss climate control.... easy as hell to change the bulbs Sad
Harty
PaddyC
PostPosted: Wed Aug 10, 2011 3:29 am Up
How does the centre console come out exactly? Do you have to unscrew things or does it pull out or are there clips holding it in place or what?
PostPosted: Wed Aug 10, 2011 3:33 am Up
Once you pull the top off, two little torx screw to remove then it pulls off,
Iirc there was a how to on here somewhere.
Harty
PostPosted: Wed Aug 10, 2011 3:36 am Up
yeah then i think its 2 torx that hold the heater controls in aswell then just gotta wrestle with the metal rods.
Harty
PostPosted: Wed Aug 10, 2011 9:54 am Up
Get your torx 20 screwdriver out, the 206 centre console comes apart so easy for replacing blown bulbs.
PaddyC
PostPosted: Wed Aug 10, 2011 10:29 am Up
Thanks everyone. Will get a go at this later tonight hopefully. What code do the bulbs have in Halfords to fir for the heaters and display unit?
PostPosted: Wed Aug 10, 2011 10:39 am Up
Heater = Peugeot / Citroen part number 6112 56 Bulb including holder £2.20 each
Display = Peugeot / Citroen part number 6112 60 Bulb including holder £3 each
PaddyC
PostPosted: Thu Aug 11, 2011 11:10 am Up
Thanks for that. Have ordered them at the local Peugeot dealer and they will contact me when they are in. Checked Halfords but they apparently don't have the lights I require. Thanks all for the help! Smile
