Posted: Tue Aug 09, 2011 12:40 pm |
New bolts sound the way forward I think I'll get some too
Posted: Tue Aug 09, 2011 2:57 pm |
Just incase anyone wants I have some spare you can have for a few quid, think they come in at least a pack of 2 or 3 and I only used one.
Posted: Wed Aug 10, 2011 9:14 am |
Went to the local Fixings shop today and got a M14 x 120mm Bolt & Nut for £1. Did the job perfectly. Will be changing all 4 this weekend for new ones.
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Wed Aug 10, 2011 12:53 pm |
| JE_180 wrote: |
| Went to the local Fixings shop today and got a M14 x 120mm Bolt & Nut for £1. Did the job perfectly. Will be changing all 4 this weekend for new ones. |
what grade are they
OEM use 6.0 grade and peugeot sport use 8.8 grade.
if the bolts is ungraded then i wouldn't use it.
Posted: Wed Aug 10, 2011 12:55 pm |
Ignore for stupidity.
Posted: Wed Aug 10, 2011 1:12 pm |
When it comes to shock absorber bolts I think anything other than the ones designed for the job is a bit stupid
Posted: Wed Aug 10, 2011 1:15 pm |
| Harry wrote: |
When it comes to shock absorber bolts I think anything other than the ones designed for the job is a bit stupid  |
if they are good grade then is fine.
peugeot sport run normal allen head bolt+ 2x washer+nut set up.
Posted: Wed Aug 10, 2011 1:26 pm |
| Seabook wrote: |
| JE_180 wrote: |
what grade are they
if the bolts is ungraded then i wouldn't use it. |
8.8 I asked for them especially.
Posted: Wed Aug 10, 2011 1:30 pm |
| Seabook wrote: |
| Harry wrote: |
peugeot sport run normal allen head bolt+ 2x washer+nut set up. |
Fair enough I will bear that for next time, I thought about it when I needed one but just it was best getting the proper one for the proper job.
Posted: Wed Aug 10, 2011 1:36 pm |
Would 12.9 Grade be a little OTT? I prefer the Allen Cap bolts to the hex bolts I have anyway so could I upgrade them all to 12.9 allens without a problem?
Posted: Wed Aug 10, 2011 1:37 pm |
| JE_180 wrote: |
| Would 12.9 Grade be a little OTT? I prefer the Allen Cap bolts to the hex bolts I have anyway so could I upgrade them all to 12.9 allens without a problem? |
see my reply above
at least 6.0.
no harm to use higher grade but it just cost you more
Posted: Wed Aug 10, 2011 1:38 pm |
| JE_180 wrote: |
| Seabook wrote: |
| JE_180 wrote: |
what grade are they
8.8 I asked for them especially. |
that fine then. make sure there is 8.8 on the actual bolts
Posted: Wed Aug 10, 2011 1:43 pm |
| Seabook wrote: |
| JE_180 wrote: |
| Seabook wrote: |
| JE_180 wrote: |
what grade are they
that fine then. make sure there is 8.8 on the actual bolts  |
lol I just double checked and there is 8.8 stamped on the head
Posted: Wed Aug 10, 2011 1:44 pm |
| JE_180 wrote: |
| Seabook wrote: |
| JE_180 wrote: |
| Seabook wrote: |
| JE_180 wrote: |
what grade are they
lol I just double checked and there is 8.8 stamped on the head  |
Posted: Wed Aug 10, 2011 1:55 pm |
| tomd0801754 wrote: |
| Ignore for stupidity. |
What a retarded and useless comment. Well done you.
