Latest: Beduff1977
Overall: 17134
Online Now [3383]:
Visitors: 3382
Today: 77512
Total: 107479191
Forums › The Car › 206 Problems › Rear shock bolt
Rear shock bolt
00budham00
PostPosted: Tue Aug 09, 2011 12:40 pm Up
New bolts sound the way forward I think I'll get some too
PostPosted: Tue Aug 09, 2011 2:57 pm Up
Just incase anyone wants I have some spare you can have for a few quid, think they come in at least a pack of 2 or 3 and I only used one.
JE_180
PostPosted: Wed Aug 10, 2011 9:14 am Up
Went to the local Fixings shop today and got a M14 x 120mm Bolt & Nut for £1. Did the job perfectly. Will be changing all 4 this weekend for new ones.
PostPosted: Wed Aug 10, 2011 12:53 pm Up
what grade are they Confused
OEM use 6.0 grade and peugeot sport use 8.8 grade.
if the bolts is ungraded then i wouldn't use it.
PostPosted: Wed Aug 10, 2011 12:55 pm Up
Ignore for stupidity.
PostPosted: Wed Aug 10, 2011 1:12 pm Up
When it comes to shock absorber bolts I think anything other than the ones designed for the job is a bit stupid Laughing
PostPosted: Wed Aug 10, 2011 1:15 pm Up
if they are good grade then is fine.
peugeot sport run normal allen head bolt+ 2x washer+nut set up.
JE_180
PostPosted: Wed Aug 10, 2011 1:26 pm Up
8.8 I asked for them especially.
PostPosted: Wed Aug 10, 2011 1:30 pm Up
Fair enough I will bear that for next time, I thought about it when I needed one but just it was best getting the proper one for the proper job.
JE_180
PostPosted: Wed Aug 10, 2011 1:36 pm Up
Would 12.9 Grade be a little OTT? I prefer the Allen Cap bolts to the hex bolts I have anyway so could I upgrade them all to 12.9 allens without a problem?
PostPosted: Wed Aug 10, 2011 1:37 pm Up
see my reply above Laughing
at least 6.0.
no harm to use higher grade but it just cost you more
PostPosted: Wed Aug 10, 2011 1:38 pm Up
that fine then. make sure there is 8.8 on the actual bolts Razz
JE_180
PostPosted: Wed Aug 10, 2011 1:43 pm Up
lol I just double checked and there is 8.8 stamped on the head Smile
PostPosted: Wed Aug 10, 2011 1:44 pm Up
Thumb Up
JE_180
PostPosted: Wed Aug 10, 2011 1:55 pm Up
What a retarded and useless comment. Well done you.
Page 2 of 3
