Online Now [467]:
Visitors: 466
Today: 56200
Total: 142200369
Forums › The Car › 206 Problems › 1.4 hdi engine noise
dtm_martin24
PostPosted: Tue Aug 09, 2011 4:00 pm Up
My hdi under acceleration makes what only can be descibed as a chuffing noise between 2500 and 3500 rpm. There is no lack of acceleration or anything. There is also excessive engine movement and a reletively rough idle which may be related. Any ideas would be appreciated as the sound is really worrying.
Peugeot 206 1.4 HDI Style 3dr
glenpring
PostPosted: Wed Aug 10, 2011 12:58 am Up
i have 1.4 hdi and i had kinda the same problem turned out to be an injector leak the part is about 12p a copper washer but it cost £200 to get the copper washer put in Sad
adsayer
PostPosted: Wed Aug 10, 2011 8:30 am Up
Glen, can you be more specific what the issue was that you had?
We've just acquired an unloved 1.4 HDi and the engine sounds a bit 'odd' at times. Not detrimentally and no lack of performance, just sounds a bit gruff at times.
Thanks!
Ads
Cars: 03 206 Look 1.4 HDi & 02 206 Style 1.4 HDi
dtm_martin24
PostPosted: Wed Aug 10, 2011 3:07 pm Up
On this subject does anyone know how to get the injector out cheaply and without destroying the injector or head as at the moment i cannot afford any special tools or to replace anything expensive. Also on this engine are the injectors coded to the ECU or are they exchangable with another hdi.
glenpring
PostPosted: Thu Aug 11, 2011 1:43 am Up
here is a vid i took of the niose thats all it was really
adsayer
PostPosted: Thu Aug 11, 2011 5:37 am Up
No that's a big help thanks. Rather loud squirty/tapping sound to me. Will keep an ear out for that one.
Ads
