Latest: Kifi69
Overall: 17183
Online Now [333]:
Visitors: 333
Today: 164929
Total: 144004897
Forums › The Car › 206 Problems › 1.1 206 W Plate Reving On Its Own...
adz2k3
PostPosted: Fri Aug 12, 2011 1:17 pm Up
Hi there guys & girls, new to the French sceen...
Basically ive just bought a 206 1.1 LX Had it a month been lovly, no problems.. but this evening.. It was reving on its own to around 3-4k without touching the throttle....
And seems to have drunk quite a bit of petrol as well.
Its only every now and again it does it... So far ive cleaned the butterfly valve on the throttle. As i fort it may of been that sticking.
Any ideas or pointers would be greatly appriciated.
Many Thanks!
Adz
coz i can!
Teebag
PostPosted: Fri Aug 12, 2011 1:18 pm Up
idle control valve needs replacing/ cleaning
my garage inc mod list:
- Antix
adz2k3
PostPosted: Fri Aug 12, 2011 1:29 pm Up
Sorry to sound silly... Is that on the tb bit at top of the engine? How do they come of? And clean with brake cleaner?
Thanks once again!
coz i can!
Teebag
PostPosted: Fri Aug 12, 2011 1:50 pm Up
take a look at the faq's and the how-to's on here. pretty sure its covered in there as i cant remember off the top of my head
- Antix
adz2k3
PostPosted: Fri Aug 12, 2011 1:52 pm Up
Hi, i did have a look in there, and all i can see is things about anti freeze and coolent and oil advice etc. Sad
coz i can!
Deckchair5
PostPosted: Fri Aug 12, 2011 2:17 pm Up
Have a look on eBay and you'll find pictures of 206 stepper motors
But the fact your engine is revving up to 4k seemingly on its own then it might well be your MAP sensor at fault which tells the ECU how much air it believes the engine is taking in and the ECU adjusts the fuel to suit that airflow. So the fact you're also burning fuel might point more to the MAP as the idle stepper motor only comes in to play at idle rpm
Even then there may be nothing wrong with your MAP sensor and may be a simple poor contact there. Easy to spot if you have an OBD interface giving you live engine running data but a first step might be to disconnect the MAP sensor and spray the connections there with electrical contact cleaner (nothing else), let it dry and then give it a try
Sometimes you need to reset the ECU by disconnecting the battery for an hour or so and then it recalibrates what it sees as the "new" MAP sensor
Antknee
PostPosted: Fri Aug 12, 2011 3:09 pm Up
Where is the map sensor located please? Smile the only picture i could find that was half decent was this one lol (sorry)
adz2k3
PostPosted: Fri Aug 12, 2011 3:15 pm Up
Is the map sensor underneath on that tb bit? like before it enters the butterfly valve bit?
To reset the ecu.. Isit a case of just leaving the battery disconnected for a hour and connecting back on.. then job done kind of thing?
coz i can!
adzar
PostPosted: Fri Aug 12, 2011 3:42 pm Up
www.206info.co.uk/Foru.../t=95.html
1.4 Sport
jamiea69
PostPosted: Fri Aug 12, 2011 3:53 pm Up
i had same problem on my first 206. it was a faulty coilpack. changed it and had no problems, i was able to drive round the block without touching the accelerator.
225 cupra r
adz2k3
PostPosted: Fri Aug 12, 2011 5:05 pm Up
That battery thing sounds bit technical to me, will it muck it up if i dont do it correct? or could i start again?
coz i can!
Deckchair5
PostPosted: Sat Aug 13, 2011 12:16 am Up
You disconnect the battery negative, you wait an hour or so, you reconnect it again. Maybe it is a bit technical Very Happy
Try your stepper motor first though
adz2k3
PostPosted: Sat Aug 13, 2011 2:34 pm Up
Oh right, didnt realise it was like that lol... I read through that post thing and it was saying about holding this button, putting headlights on etc.. lol.
And the stepper motor?? what bit is that sorry.
coz i can!
adzar
PostPosted: Sat Aug 13, 2011 4:12 pm Up
From what I understand, you should follow the procedure for battery disconnection 'whenever a vehicle battery has to be disconnected' as described in that topic. And it's not really that complicated - just read through it first so you know what you're doing.
1.4 Sport
Ash
PostPosted: Sat Aug 13, 2011 4:58 pm Up
Is the battery in good condition?
