Online Now [143]:
Visitors: 142
Today: 35962
Total: 138715067
Forums › The Car › 206 Problems › Washer Jets
Washer Jets
AshH
PostPosted: Sat Aug 13, 2011 1:27 pm Up
Ok well just went out to the car and filled the washer bottle up. And then gave the washer jets a blast to notice that the drivers side is bang on. But the pasengers side sprays only from 1 and the 1 it does goes straight over the car :S lol
How do i adjust these? And i plan on getting some PH2 1s, would this sort the problem??
Thanks, Ash.
Team - 180
Team - ATM!!!
eddrj
PostPosted: Sat Aug 13, 2011 1:33 pm Up
yeah probably would sort out problem , phase 2 s are soo much better had them on my 206,
big improvement than the old phase 1 washer jets.
Easy and cheap mod worth doing.
There bout £12 new ebay or get them really cheap at a scrapyard .
Old car 2000/ 206 2.0 hdi.
AshH
PostPosted: Sat Aug 13, 2011 1:44 pm Up
I was gonna do it anyways just wanted to know if it would sort the problem out aswell lol .. killing to birds with 1 stone Very Happy
Team - 180
Team - ATM!!!
brimbo
PostPosted: Sat Aug 13, 2011 2:04 pm Up
Get a pin, or a needle, something like that, and stick it in the actual outlet, give it a wiggle around, and its just trial and error from there Very Happy
W-reg 1.4 LX
eddrj
PostPosted: Sat Aug 13, 2011 2:29 pm Up
the pin trick might work but phase 2s,
much better up 2 u
ExoVyper
PostPosted: Sat Aug 13, 2011 2:56 pm Up
the pin method will clear the blockage in the jets but once you pull the stalk it'll block again.
best thing to do is like said above just grab the phase two jets as they're miles better or if your sticking with yours for a bit take the washers out the bonnet ram the needle down them and put it under the tap to fire the dirt/muck out the back rather than just put it back down the pipe ^_^
meady
PostPosted: Sat Aug 13, 2011 4:03 pm Up
Trade Rating: +45
also why pay £12 from ebay when they are about £4-£5 each from the dealers
TEAM - I HATE FACEBOOK Smile
Tam80
anybody got an ebay linky for the phase 2 jets ?
cheers Thumb Up
206/GT/GTI
dafdavies
PostPosted: Sat Aug 13, 2011 4:15 pm Up
I agree! What He Said
Team: If you cant find the tool you need make one
Ash
PostPosted: Sat Aug 13, 2011 4:59 pm Up
Undo it and blow compressed air through. Works perfectly. And it *should* solve the jet going over the car.. Sounds like the excess pressure due to the blockage is causing that.
PostPosted: Sun Aug 14, 2011 4:34 am Up
cheers Thumb Up
There cheaper from a Peugeot main dealer Wink
Stop wasting money & getting ripped of from Ebay.
brimbo
PostPosted: Sun Aug 14, 2011 8:25 am Up
Getting mist-type would be a lot better, but if your preferring the phase 1 types then try the pin trick Very Happy If not, you could probably pick up some phase 2's from the scrappy for about, £1? possibly free if you work your magic and charm the blokes
W-reg 1.4 LX
PostPosted: Sun Aug 14, 2011 8:31 am Up
Don't know about phase 1 jets, but I used to adjust washer jets using a pin. You could move the nozzle around in the housing and get it spraying just where you wanted.
