Latest: Beduff1977
Overall: 17134
Online Now [872]:
Visitors: 871
Today: 174020
Total: 107575637
Forums › The Car › 206 Problems › weird one
weird one
Tam80
PostPosted: Sun Aug 14, 2011 10:17 am Up
noticed that my battery light was on after starting the engine...very very dim...gotta cover it with my hands as its sunny here to see it its that dim...
then i noticed that my display/clock and my heating thingy were dead as well...few turns of the key later and they come back on..still got the battery light on dim
have checked fuses/aux belt...all seems fine
any ideas you clever people ?
cheers Thumb Up
206/GT/GTI
Lecktorious
PostPosted: Sun Aug 14, 2011 10:19 am Up
Trade Rating: +59
Battery or alternator.
'98 Nile Blue 306 GTi 6
PostPosted: Sun Aug 14, 2011 10:46 am Up
Is this before or after you have tried fitting your flashing led?
www.206info.co.uk/Foru...35493.html
Tam80
PostPosted: Sun Aug 14, 2011 11:36 am Up
Cheers G Wink
206/GT/GTI
Tam80
PostPosted: Sun Aug 14, 2011 11:37 am Up
can you multi quote on this ?
never done nothing with the wires...only drilled hole in plastic for the LED
206/GT/GTI
PostPosted: Sun Aug 14, 2011 12:06 pm Up
I was just making sure you hadn't dislodged anything by trying to fit the led.
You did remove the cowling before drilling didn't you?
Not trying to pick holes in you, but there are some people on here that will do one job and then ask a question about something else, which resulted due to bad workmanship of the first thing they did.
Lee wrote:
Start the car and put a multimeter on the terminals, a healthy alternator will make the reading about 13.5-13.7 volts
Test the battery first thing in a morning when the car has been stood all night, and you will get a more accurate reading of the battery charge. If you look in the beginners guide to a 206 I put a list of voltage vs charge
Tam80
PostPosted: Sun Aug 14, 2011 12:51 pm Up
lol yeah i did remove the cowling mate
was thinking fuse at first...checked them all...then maybe a dodgey wire behind radio somewheres...but when it come back on by itself lol
could this be linked to my battery light coming on you think ?
206/GT/GTI
