Forums › The Car › 206 Problems › Rear shock bolt |
Posted: Sun Aug 14, 2011 1:46 pm |
JE_180 wrote: |
Well they're gona ask for a part number which I'm going to reply "f*** knows". |
It's the parts mans problem of finding the part numbers. Just tell him what you want and let him find the part numbers. Don't forget you need boths nuts and bolts.
Some tools that don't round off the nuts would be a good investment too.
Standard bolts are more than adequate for all road cars.
