Online Now [239]:
Visitors: 238
Today: 72652
Total: 143062713
Forums › The Car › 206 Problems › hdi injectors
hdi injectors
dtm_martin24
PostPosted: Mon Aug 15, 2011 4:02 pm Up
My 206 1.4hdi injectors o rings and copper seals need changing, have removed enough of the top of the engine to get clear access only to discover that the are seized into the engine, are there any cheap way to remove the injectors safely as i can't afford to damage any expensive components at the moment.
Peugeot 206 1.4 HDI Style 3dr
PostPosted: Mon Aug 15, 2011 4:53 pm Up
you need proper hydraulic puller to remove the injector, or at least a sliding hammer with proper adaptor
there is no way you can remove them by bare hand.
dtm_martin24
PostPosted: Mon Aug 15, 2011 5:08 pm Up
fair enough, rough price for correct tool and where i can get it from?
