Posted: Wed Aug 17, 2011 5:36 pm |
Also test the injectors first before you go replacing them.
Posted: Thu Aug 18, 2011 3:54 am |
MrBSI wrote: |
Is the engine management light on?
Should be a fault code stored at least.
Cylinder 1 is the gearbox end when you find out which pot is missing. |
The light comes on intermittently when driving, never happened on idle.
Posted: Thu Aug 18, 2011 5:10 am |
y3Lo wrote: |
MrBSI wrote: |
The light comes on intermittently when driving, never happened on idle. |
Read the fault codes then, it should give you a big clue to which cylinder is misfiring.
Posted: Thu Aug 18, 2011 7:09 am |
MrBSI wrote: |
y3Lo wrote: |
MrBSI wrote: |
Read the fault codes then, it should give you a big clue to which cylinder is misfiring. |
Posted on 15th 'p0200 intermittent misfire' that's all that's coming up.
