Posted: Sat Aug 20, 2011 4:01 am |
INFO:
Peugeot 206 GTi 180
54 Plate
Been coming up for ages now! Just been going to my local and getting it turned off.
However, went today and done the reader, its come up summet about Air Feed summet or other :S :/
Anybody know about this? Had this problem? How you over come it?
All help would be great.
Thanks, Ash.
| | ![](images/spacer.gif) |
Posted: Sat Aug 20, 2011 5:14 am |
I had one the other day and it was the lamba sensor plug came apart
Posted: Sat Aug 20, 2011 5:18 am |
The warning that comes on screen is Anti-Polution Fault :/ if that helps!
Posted: Sat Aug 20, 2011 5:52 am |
9/10 anti polution fault means the cat or lamba sensor etc what was the fault code when it was read?
Posted: Sat Aug 20, 2011 5:54 am |
Didn't go the old man went and being 50 he couldn't tell me xact :/ ... Iv been told that it may be the Fuel Filter :/ ??????
Posted: Sat Aug 20, 2011 5:59 am |
Could be any of 1001 things, get the code properly next time and we'll be able to help. Otherwise you're just chasing shadows.
Posted: Sat Aug 20, 2011 6:06 am |
Ill try get intouch with the mechanic and see if he remembers lol
Posted: Tue Aug 23, 2011 5:02 am |
I had this problem on my 1.6HDi last week - Turns out it was the EGR Sensor/Valve - Removed > Cleaned off all the crap > rebuilt > problem has now gone away, so maybe worth a check.
Posted: Tue Aug 23, 2011 5:32 am |
That 'Antipollution Fault' message isn't specific to one thing. It could be any fault code so the ECU will need to be read to get the exact fault code.
You need to get the P code and then look it up to get the definition. Don't clutch at straws as you will only waste money.
Posted: Tue Aug 23, 2011 5:58 am |
When I had Anti Pollution Fault it turned out to be a faulty coil pack
