Online Now [124]:
Visitors: 123
Today: 25341
Total: 138815770
Forums › The Car › 206 Problems › After trying to solve the reving.. Its still reving lol
adz2k3
PostPosted: Sat Aug 20, 2011 12:11 pm Up
Well... Today we took the complete throttle body of... cleaned it right out, and the same with the stepper motor/icv...
We pluged it into a computer.. for it to say everything is working as it should... all bar the CTS coolent temp sensor... would this make it struggle to start, and rev like it does.
The computer was saying the cts temp was -40degrees...
Thanks for your input once again.
coz i can!
Quarmbo
PostPosted: Sat Aug 20, 2011 1:08 pm Up
When my old 1.1 used to rev its nuts off, then die, then rev its nuts off, it turned out to be my coolant temp sensor. Cheap part, replace it and see if it works
Ford SportGay-A
adz2k3
PostPosted: Sat Aug 20, 2011 1:09 pm Up
Cheers mate, going to give it a try next week well monday when motor factors are open Smile hopefully it will solve it...
Anyone know how easy it is to do a clutch?
coz i can!
oldskoolz
PostPosted: Sat Aug 20, 2011 1:27 pm Up
if the CTS doesn't sort it change your ICV and MAP sensor, but seeing as you got a reading of -40 it seems to be the CTS at fault
Black 206 Gti. Soon to be 2.2
pug206lx
PostPosted: Sat Aug 20, 2011 2:56 pm Up
The coolant temperature sensor will cause problems because the ECU thinks the engine is at a different temperature to what it actually is, ie warm when its cold or cold when its warm.
I had my 206 stalling and running rough when cold about 2 months ago, the gauge was also moving about a lot and always showing warm - replaced the coolant temperature sensor and not seen the problem since. Was about £30 from Peugeot.
adz2k3
PostPosted: Sat Aug 20, 2011 3:48 pm Up
Cheers buddy Smile Will get one first thing monday morning from motor factors Smile
coz i can!
adz2k3
PostPosted: Fri Aug 26, 2011 4:19 pm Up
The CTS has seemed to solve the revving problem and is now reading 70ish degrees... Smile
Cheers guys!
coz i can!
