Latest: cogeim7
Overall: 17185
Online Now [3533]:
Visitors: 3532
Today: 146672
Total: 147045075
Forums › The Car › 206 Talk › strutbrace
strutbrace
Forum Index › 206 Talk
craigdmjv
PostPosted: Sat Aug 20, 2011 9:11 am Up
hi this might be in the wrong section but my son tried to fit his new strutbrace to his cinq today but the holes dont line up with the strut bolts its a couple of mms out so i wondered if it would cause any problems if i drilled the holes a little bigger
macj
PostPosted: Sat Aug 20, 2011 9:14 am Up
have you a picture to show how far out it is
PostPosted: Sat Aug 20, 2011 9:16 am Up
did you install it the other way round?
craigdmjv
PostPosted: Sat Aug 20, 2011 9:17 am Up
ill get one now mate
PostPosted: Sat Aug 20, 2011 9:46 am Up
If it's only 2mm then I'm sure you can drill the strut brace holes a little bit. Or can the strut top bolts be loosened and moved slightly?
macj
PostPosted: Sat Aug 20, 2011 11:17 am Up
moving the top mounts Thumb Up
good call
craigdmjv
PostPosted: Sat Aug 20, 2011 1:52 pm Up
they aint bolted like some heres the auction www.ebay.co.uk/itm/110...500wt_1156
macj
PostPosted: Sat Aug 20, 2011 3:22 pm Up
its adjustable on the width so I cant see the problem without a photo
PostPosted: Sat Aug 20, 2011 3:40 pm Up
I had a Cinquecento Sporting when they first came out...best small car you could buy back then.
Couldn't be bothered driving it hard round country lanes because the bodyroll was a little off putting.
borinous
PostPosted: Mon Aug 22, 2011 6:18 am Up
Completely different car but when i fitted a front fixed strutbrace to my Suzuki Swift GTi the holes where out by a few mm.
Solution was to jack the car up so the wheels where free from the ground, attach the brace to one side and then using something for leverage force it on the other side. with the wheel free from the ground you are able to get some movement in the suspension top mounts.
Dont really want to drill out the holes as this would surely defeat the objective of the strutbrace?? its meant to stop the movement in the top mounts.
Hi
craigdmjv
PostPosted: Mon Aug 22, 2011 6:28 am Up
its a 900 but he is making it handle better than a sporting with a strutbrace 50-70 kit sporting wheels(wider) and a lower arb
