Latest: Beduff1977
Overall: 17134
Online Now [1338]:
Visitors: 1337
Today: 224670
Total: 107884690
Forums › The Car › 206 Problems › Seized like you wouldn't believe!! ***SORTED***
alyoung
PostPosted: Mon Aug 22, 2011 8:40 am Up
Trying to change my front brake discs on my 1.9D, got the calipers and locking screws off no problem but the discs are seized, unbelieveably.
I've tried WD-40, Freeze Spray and heating the disc but they won't even budge. I'm pretty sure the problem is between the mating faces of the hub and the internal circumference of the discs.
I've battered them severely with a hammer and they haven't moved.
Any other ideas/solutions that I'm missing?
Thanks.
Al
2001 1.9Diesel (No ECU)
PostPosted: Mon Aug 22, 2011 8:45 am Up
Grinder, cut a slot in to the disc & a nice big wack with your chisel will soon break the disc free Wink
alyoung
PostPosted: Mon Aug 22, 2011 8:48 am Up
Grind from the edge -down?
PostPosted: Mon Aug 22, 2011 8:49 am Up
Yes, splits the disc, be carefull that you only cut in to the disc!
00budham00
PostPosted: Mon Aug 22, 2011 8:50 am Up
Bigger hammer
alyoung
PostPosted: Mon Aug 22, 2011 8:51 am Up
00budham00 wrote:
Bigger hammer
Trust me...tried that, bits of disc everywhere!
PostPosted: Mon Aug 22, 2011 8:52 am Up
Sledge hammer
Or lees d**k
Either works well
Addaz wrote:
Sledge hammer
Or lees d**k
Either works well
He is still on holdiay Laughing
alyoung
PostPosted: Mon Aug 22, 2011 8:53 am Up
Addaz wrote:
Sledge hammer
Or lees d**k
Either works well
Hard to do that lying on your side with the car on axle stands...with the Sledge Hammer, that is Wink
LilLew
PostPosted: Mon Aug 22, 2011 8:54 am Up
if i am correct try a sliding hammer on the back of the disc
2003 Pug 206 2.0 GTI 180
ExoVyper
PostPosted: Mon Aug 22, 2011 8:55 am Up
when ever this used to happen to us at the garage the solution was hit it that hart you split it in two as after all.... it's not tlike you were putting them on again xD
glenpring
PostPosted: Mon Aug 22, 2011 9:04 am Up
could you not drill the holes a bit bigger then put every thing back on and drive a little then slam your brakes on?
Big_Rich180
PostPosted: Mon Aug 22, 2011 9:20 am Up
Always got safety in mind Laughing
MrrNoName
PostPosted: Mon Aug 22, 2011 9:22 am Up
LOL
glenpring
PostPosted: Mon Aug 22, 2011 9:38 am Up
just a thought lol if you do do that could you video it an put it on youtube lol
