Posted: Mon Aug 22, 2011 8:40 am |
Trying to change my front brake discs on my 1.9D, got the calipers and locking screws off no problem but the discs are seized, unbelieveably.
I've tried WD-40, Freeze Spray and heating the disc but they won't even budge. I'm pretty sure the problem is between the mating faces of the hub and the internal circumference of the discs.
I've battered them severely with a hammer and they haven't moved.
Any other ideas/solutions that I'm missing?
Thanks.
Al
Posted: Mon Aug 22, 2011 8:45 am |
Grinder, cut a slot in to the disc & a nice big wack with your chisel will soon break the disc free
Posted: Mon Aug 22, 2011 8:48 am |
MrBSI wrote: |
Grinder, cut a slot in to the disc & a nice big wack with your chisel will soon break the disc free  |
Grind from the edge -down?
Posted: Mon Aug 22, 2011 8:49 am |
alyoung wrote: |
MrBSI wrote: |
Grind from the edge -down? |
Yes, splits the disc, be carefull that you only cut in to the disc!
Posted: Mon Aug 22, 2011 8:50 am |
Bigger hammer
Posted: Mon Aug 22, 2011 8:51 am |
00budham00 wrote: |
Bigger hammer |
Trust me...tried that, bits of disc everywhere!
Posted: Mon Aug 22, 2011 8:52 am |
Sledge hammer
Or lees d**k
Either works well
| Team Impossible Possible
Addaz wrote: |
Sledge hammer
Or lees d**k
Either works well |
He is still on holdiay
Posted: Mon Aug 22, 2011 8:53 am |
Addaz wrote: |
Sledge hammer
Or lees d**k
Either works well |
Hard to do that lying on your side with the car on axle stands...with the Sledge Hammer, that is
Posted: Mon Aug 22, 2011 8:54 am |
if i am correct try a sliding hammer on the back of the disc
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
Posted: Mon Aug 22, 2011 8:55 am |
when ever this used to happen to us at the garage the solution was hit it that hart you split it in two as after all.... it's not tlike you were putting them on again xD
Posted: Mon Aug 22, 2011 9:04 am |
could you not drill the holes a bit bigger then put every thing back on and drive a little then slam your brakes on?
Posted: Mon Aug 22, 2011 9:20 am |
glenpring wrote: |
could you not drill the holes a bit bigger then put every thing back on and drive a little then slam your brakes on? |
Always got safety in mind
Posted: Mon Aug 22, 2011 9:22 am |
glenpring wrote: |
LOL
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Mon Aug 22, 2011 9:38 am |
Big_Rich180 wrote: |
glenpring wrote: |
Always got safety in mind  |
just a thought lol if you do do that could you video it an put it on youtube lol
