Online Now [48]:
Visitors: 47
Today: 69705
Total: 105112005
Forums › The Car › 206 Problems › 206 hatch vs CC rear light clusters
gazza82
PostPosted: Tue Aug 23, 2011 10:19 am Up
What's the difference?
I'm sure I've read somewhere that hatch clusters can be modified to fit, so I assume there is a small difference?
I'd like to fit a pair of Phase 2s to the CC.
AshH
PostPosted: Tue Aug 23, 2011 10:22 am Up
Think its the rain gaurd, the little black bit inside :/ not to sure dont hold me to it! But can be modded mate!
Team - 180
Team - ATM!!!
Antknee
PostPosted: Tue Aug 23, 2011 10:32 am Up
it is indeed, if you buy some you can trim the plastic flappy bit to size using your current CC ones as a template
fatboyslim
PostPosted: Tue Aug 23, 2011 1:37 pm Up
Loads of proper CC lights on Ebay
Yes I own a CC and I'm neither gay or a hairdresser!!
PostPosted: Tue Aug 23, 2011 1:45 pm Up
Surely you can buy some phase two CC lights from somewhere?
PostPosted: Tue Aug 23, 2011 3:17 pm Up
100% correct, the black plastic rain guard clipped on to the cluster, easily swoppable if you want.
gazza82
PostPosted: Sat Sep 03, 2011 11:10 am Up
Add CC to the search and the price goes up!!
You can get LED hatch rear brake lights for around £20, but go for same for CC and you're looking at £35!! Same with rear light clusters.
craigdmjv
PostPosted: Sat Sep 03, 2011 11:58 am Up
i got mine for 15 inc postage ill pm you a 206cc breakers that is very cheap
craigdmjv
PostPosted: Sat Sep 03, 2011 12:04 pm Up
pm'd
gazza82
PostPosted: Mon Sep 05, 2011 3:05 am Up
OK, checked the rear lights and the lamp is the same. The difference is the black splash guard which is much larger on the hatch version. But this seems to just clip on .. so next up is a bit of work with some small screwdrivers, etc., to see if I can get these off in one piece. Then do same for existing CC lamps, swap and put back!
Should be interesting ...
copey
PostPosted: Mon Sep 05, 2011 3:17 am Up
this is exactly what was said above
02 2.0 hdi d turbo
gazza82
PostPosted: Mon Sep 05, 2011 6:37 am Up
I missed Mr BSI's post ... Sad
But I'll also question the "easy" bit .. mine attempts at the weekend didn't get one off. The three clips aren't that easy to move (I managed one!) and it looks like it may also be "plastic welded" at the top and bottom corners. There's a little round fitting that definitely doesn't want to flip off that easily.
As I'm working on the Phase 2's at the moment, I obviously am taking my time as I don't want to break them!
