Latest: lio94
Overall: 17181
Online Now [504]:
Visitors: 503
Today: 68794
Total: 141823350
Forums › The Car › 206 Problems › 206 hdi turbo sluggish acceleration
Adazrambo
PostPosted: Thu Aug 25, 2011 7:10 am Up
between 2500 rpm - 3000 i had my foot to the floor and i would barely move. Turbo seems ok no whinging and works ok at lower revs. Possible EGR valve? or bit of dirt stuck?
206 hdi turbo
Antknee
PostPosted: Thu Aug 25, 2011 7:18 am Up
have you got the EGR unplugged? if not i would do that anyway
Adazrambo
PostPosted: Thu Aug 25, 2011 7:21 am Up
No I just heard about it but know nothing about the EGR itself or where it sits. How do i do this and what are the benefits?
Cheers
206 hdi turbo
Antknee
PostPosted: Thu Aug 25, 2011 7:44 am Up
is yours a 2.0 or 1.4 orr 1.6?
The 1.4 is easy you just have to unplug the blue (i think) plug on the firewall underneath the wipers, the egr just recirculates some of the exhaust gasses through the engine to reduce emissions but it also makes you lose power, if you unplug the valve it stops the gasses going back through which gives you a more efficient burn and since diesels arent tested for emmisions it doesnt make any difference to the MOT
qwert
PostPosted: Thu Aug 25, 2011 7:46 am Up
Unplugging the egr uses more fuel, and makes it harder to start in winter. Pointless mod, makes no good common sense
brum brum
MRyan89
PostPosted: Thu Aug 25, 2011 7:49 am Up
I am so doing that after work, is it just as easy as unplugging that one plug?
Adazrambo
PostPosted: Thu Aug 25, 2011 7:50 am Up
it is the 2.0 mate
206 hdi turbo
Aar_Im_A_Pirate
PostPosted: Thu Aug 25, 2011 7:52 am Up
fuel pressure rail?
Team: Derv
Antknee
PostPosted: Thu Aug 25, 2011 7:57 am Up
it might be worth looking up the original problem on tdocuk.co.uk, its pretty useful
and im not sure about how to go about unplugging it on a 2.0 but again it should be on that site in the how-to section
and yeah its just one plug
and it did make a difference on my car, it did drop about 5mpg but i am willing to sacrifice that for the difference it made to how it drives without it..
Adazrambo
PostPosted: Thu Aug 25, 2011 8:06 am Up
Thanks - appreciate your help!
206 hdi turbo
cartoonhead
PostPosted: Thu Aug 25, 2011 8:11 am Up
whens the last time the car was serviced ?
could be the pre filter thats on the fuel sender in the tank.
if it gets to the point that when you try to rev above 2500 and it cuts out chances are it's starting to get blocked.
just a case of removing the sender from the tank ( under the black plate under the driver side rear seat ) , pulling the filter off and giving it a good clean.
PostPosted: Thu Aug 25, 2011 10:16 am Up
First and most simplest question.. Does it go over 3k revs?
PostPosted: Thu Aug 25, 2011 10:23 am Up
if you got no power after 2K rpm that means a dead turbo or boost leak
PostPosted: Thu Aug 25, 2011 10:30 am Up
Also shortens the turbos lifespan Wink
Quasar911
PostPosted: Thu Jan 23, 2014 7:11 am Up
mine does this and I find the easy fix is this.
get car to 50
clutch down, turn key off
foot down on gas
turn key on
rev to 7k or so, Engine light will flickers
drive normally, turbo wil kick in
