Latest: jackrox1992
Overall: 17186
Online Now [702]:
Visitors: 701
Today: 155803
Total: 148523108
Forums › The Car › 206 Problems › 206 Throttle Cable Automatic
jaypug206
PostPosted: Mon Aug 29, 2011 4:31 am Up
Hi,
On 206gti.net/throttle-cable/ it shows you how to adjust the throttle cable to make the throttle a bit more responsive.
Has anyone got a automatic 206 like me? If you have could you please tell me how many notches you have sticking out on the accelerator cable (has a silver clip) near the Idle control valve.
The link shows pictures of where the accelerator cable is located.
I would really appreciate it if you could let me know also what rev does your 206 automatic idle at in park gear and drive please.
Thank you.
2004 206 1.4 S Auto
furryhobnob
PostPosted: Mon Aug 29, 2011 4:34 am Up
On my Gti I think it was 12 notches above the clip
Deckchair5
PostPosted: Mon Aug 29, 2011 5:12 am Up
Rather than "number of notches" which will depend on car and cable stretch then the adjuster is just to take up excess slack, so once you have very little slack in the cable, just enough slack so it's not operating the throttle at idle, then that's where to clamp it
jaypug206
PostPosted: Mon Aug 29, 2011 5:29 am Up
Thanks Dechchair, just worried if I set to many notches I could damage my car, is that possible or am I worrying 2 much?
2004 206 1.4 S Auto
PostPosted: Mon Aug 29, 2011 5:36 am Up
you can't do it that way.....
you would either end up with too tight (throttle open too much when idle) or too loosen (throttle only open when excess pedal travel apply)
Ash
PostPosted: Mon Aug 29, 2011 7:45 am Up
I inboxed you what I thought you wanted.
