Latest: Beduff1977
Overall: 17134
Online Now [566]:
Visitors: 565
Today: 203301
Total: 107604873
Forums › The Car › 206 Problems › Rear Axle Replacment
Go to page Previous  1, 2, 3
PostPosted: Thu Sep 01, 2011 3:55 pm Up
Linkpad wrote:
So once u undo the hex night the brake fluid seals off?
Nope the end of the pipe will be open, but fluid wont come rushing out it will drip, you will have to bleed the brakes afterwards, id get some fresh fluid & bleed all 4 corners.
Id use the correct sized flare spanner on brake pipes, normal open ended spanners can end up causing you issues if it chews the hex of the pipe fittings up.
Page 3 of 3
