Latest: Stu-mill
Overall: 17131
Online Now [206]:
Visitors: 205
Today: 41775
Total: 104678024
Forums › The Car › 206 Problems › bonnet air vent
bonnet air vent
Mooseteets
PostPosted: Sun Sep 04, 2011 10:12 pm Up
hi all, just signed up and i have just acquired a 206gti which has a few weird "features". First off i noticed when it was raining heavily the other day, that the air vent in the bonnet seems to collect rainwater rather well.
i opened the bonnet to fill up the washer bottle and noticed a load of water where the driver side spring/shock mount is,
is this normal for it to collect water here ?
is it possible to just seal up the air vent on the bonnet ?
it does not look like it actually provides any airflow to anything vital in the car, as there's a gasket around the engine bay and this vent is sat outside that gasket when the bonnet is shut.
i have searched and not found anything (anyone with a similar complaint infact), so any advice would be appreciated.
Moooo
craigdmjv
PostPosted: Sun Sep 04, 2011 11:52 pm Up
it provides air to the interior air vents and pollen filter iirc
craigdmjv
PostPosted: Sun Sep 04, 2011 11:53 pm Up
although it shouldnt collect water do you have a black plastic cover under it around the suspension mounts
jimjam19927
PostPosted: Mon Sep 05, 2011 3:30 am Up
I have an sp grill and the bottom water catcher bit from my old grill which had a bit of mesh does not fit onto it. :/
Member: 685
I Over Use Smilies Razz
MrrNoName
PostPosted: Mon Sep 05, 2011 3:59 am Up
I cut the bottom from the old standard grill off and glued it to the underside of the sp grill, it works great and prevents water from collecting around the suspension mount.
You shouldnt seal it up, it would starve your blower motor of airflow. The pollen filter resides at the rear of this compartment
devotedsniper
PostPosted: Mon Sep 05, 2011 4:20 am Up
Mine collects water also, only a small bit on the dip which is close to the ECU, provided it's been painted properly i can't see it causing to much harm provided you have the plastic cover for the top of the struct. It is abit of a design flaw though in my opinion.
Now a 2010 Renault Megane Coupe owner
Mooseteets
PostPosted: Mon Sep 05, 2011 6:05 am Up
thanks for the replies,
this is what i was thinking myself, a bit of a design flaw, im tempted to just paint the metal parts with bitumin paint or something similar for water resistance.
Moooo
